P500 Winch Install Advice
ChrisO83
7
Park City, UT
Hello All,
I'm new to the P500 and I'm installing a SuperWinch Terra 25SR as a first time project.
I'm trying to find the best place to mount the solenoid so its close to the battery, in a relatively dry location and easy to get to; any recommendations?
Also, I'm hoping the circuit breaker will fit in the battery box with a little bit of coaxing.
Additionally, what is a good location to mount the remote socket plug? I thought the grill might be nice but I don't have the means to modify in a proper manner as I am in a remote location with limited tools and supplies.
Lastly, I might tap into the "accessory power socket" for power assuming it's a switch circuit, which wire is the hot?
Thanks for your help.
182,057
Mounted my solenoid to the firewall. Circuit breaker on frame under hood, gotta be able to get to it without messing with that battery box too much. I put my remote socket next to the cig lighter. You never know when putting it off to one side if that'll be the one buried in mud. Cig lighter should have a green and a white, pretty sure green is hot.
dls1966
dls1966
192
569
Kawkawlin Michigan
I couldn't find a spot near the battery to mount mine so I put it under the hood I just switched the long wires for the short wires I've got the superwinch 3500 it's probably pretty much the same wiring
20181011 200155
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I assume the Pioneer 500 is somewhat similar to other Honda products, i.e, Foreman in terms of wiring/winch. When wiring, I would give consideration if you want it to operate without the key on or hot (work without the key on). Personally, I think having the key on is a good option. As for mounting, I would place the connection sections well under the hood and high, but other folks here may have other great options for consideration....
ChrisO83
7
Park City, UT
Thanks, great info. I just found a post for the ultimate super winch install guide which is very helpful as well. The trick, it looks like, is to flip your wiring from battery to winch the opposite direction to facilitate a suitable location for the solenoid. Looks like the factory accessory wiring harness (08Z08-HL5-A00) to the under hood plug is a good option as well.
Reactions: trigger
Kracker
Kracker
127
227
Louisiana
Hello All,
They sell a lil cheap harness, Honda accessory harness... there a post on it by choog... for remote power on eBay for like 9$... I think I only paid 10$ at the dealership... gives 4 wire up options no splicing plug and play... sticky thread on it
P500 Accessorry sub harness description
