P1000 Winch mount question
Locohonda
Locohonda
117
Northern Va
OK guys I’m confused.
What is the difference between this......
2AE3A122 9A06 4D67 AE35 350FA30BBB46
and this?
91CD551C 8F73 4573 8477 DC423BF4FCF2
WillyNilly
WillyNilly
South Ms.
and this?
The one on the bottom is designed specifically for the Honda and has the wiring harness for the winch, the other does not appear to be specific. Before i bought my bumper I used the KFI winch mount. Worked fine, only thing i didn't like about it was the angle it had comming thru the fairlead. You can buy a mount and an aftermarket winch for way less than what Honda wants for it.
Locohonda
Locohonda
117
Northern Va
The one with the wiring harness is 3 times the price and looks like 10 times harder to install.
WillyNilly
WillyNilly
South Ms.
Yep, I put washers as spacer on my kfi to try and reduce the sharpe angle. I think the honda one sits with an angle so there is not such a shrape angle on the line coming thru the fairlead, I think; Don't quote me on that.
Locohonda
Locohonda
117
Northern Va
So the only difference between the two mounts is the wiring harness?
RedFred1
RedFred1
301
619
North Carolina
I am in the process of installing the Honda winch and mounting kit on my 2016 3pax. I got the kit and parts when I bought my buggy so I got a good discount on them and some bonus points to buy other stuff later. I am doing the Horn and backup alarm at the same time. My only issue so far has been the instruction set is hard to inderstand and some wiring harnesses were not mentioned as needed before hand. I also am going to add a second battery and control while I have it all apart. My thought is it is almost always better to buy product specific parts, when available, then to try and cheap out for aftermarket that almost always seem to have fitment problems.
208,728
First, WELCOME! The dealer installed mine and put the winch control plug in, in the glove box, it's ok, but I think it would be handier on the dash some where for the controller that has the extension cord thingy, other wise a rocker switch will suffice in most situations, been in one situation where none of the above would work, all ways best to ride with @GlockMeister, @Ragnar406 and other friends, HA!:confused: I would install the dual battery set up first, then the other accessories , that way you can check things as you go and not have to back track. Happy Trails! Reminds me, Khan where did you get your snach block? I think I need one!
