P1000 Winch mount questions
Jakey
81
139
San Francisco Bay Area
I am preparing to order a terra 45 and a mount for my P1k. I have read all the threads and from what I see, the winch is not properly positioned with regard to the bumper and fairlead location. It appears the winch sits well below the opening, and the line must come up from the bottom of the spool, then make a hard bend through the fairlead. If I was always winching to a point higher than the bumper, I wouldnt worry, but that isnt the case. I will use it for dragging downed trees and clearing roads as much as for recovery. I am looking for input from those who are using this setup, with say a KFI mount, as to how bad it is. I am also thinking, that because of the severe angle, a wire rope will be better than a synthetic running that sharp angle. A wire rope through a roller fairlead, I think, would lessen the issue. I don't want to or need to spend 5-700 for a new bumper than mounts the winch on top where it should be. Thanks, Merry Christmas.
ToddACimer
ToddACimer
Pioneer 1005-2
3,659
15,383
Oshkosh, Wi
I relocated my fairlead for a straight line pull. I like the KFI mount as it ties into the frame at the lower bumper mount and the front differential lower mount.
IMG 20161210 140014386 15192531 10100563275563117 352336562634053615 n
Jakey
81
139
Just get an EMP mount and it works fine. The EMP inverts the winch allowing it to spool straight out. I'll be switching mine to synthetic when I get everything wired.
Im not sure I understand what you mean. Does the winch mount upside down so the pull comes from the top, thereby letting it spool straight out? Doesnt that defeat the reasoning behind the winch spooling from the bottom?
Never mind, I'm an idiot. I went to their website and understand. Are the fitment issues I have read about worked out yet?
Lmao..
I had no fitment issues once I rotated the winch plate 180 degrees.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,026
Bella Vista, AR
I installed on an EMP mount as well - I had to leave the bolts loose (as directions say) and then tighten them up once on the machine. I ended up making it harder than it was. Just get a bendable 14mm wrench before you start. I have everything wired up just need to test it out under load.
Reactions: JTW
lrandy129
lrandy129
Curmudgeon
NELA
EMP plate works fine. If you don't rotate it 180° then the side mount bolts for the bumper to frame connections won't quite make up.
The other thing to watch for is the winch plate braces that attach to the P1K frame may not be bent down enough and could contact a frame cross-brace causing you fitment problems.
Make sure the plate is positioned properly and bend the winch plate braces and you should be good to go.
I didn't need to bend the braces once rotated.
Reactions: Ridem32
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
I never had a problem with the KFI mount (and used it alot unfortunately lol). But it is at a bad angle. I have cable. I'm gonna build some top mounts for the stock bumper soon, but that doesn't do you any good now.
Reactions: JTW and Ridem32
Do you plan on making them available to the membership? Will they work for SuperWinch also?
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
Yessir sure do. No idea when I can get started on it due to work. Guess may have jumped the gun when I said soon. I'll keep y'all updated
Reactions: Ridem32
Very cool! And where is it exactly that it will mount to the stock bumper?
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
Limited options with that bumper. That flat spot looks like the best spot. Shelf type mount with triangle shaped sides. Bolted at top and along sides. The stock bumper is alot stronger than I thought it'd be. Joey and I winched mine using one of the tubes and it held fine.
Reactions: Tigermark
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
Always open for suggestions. Make it a group effort lol.
That's good news that the bumper is strong. I haven't seen my unit yet and won't for a couple more weeks, but when I do, I'll look it over and give plenty of thought to it, and if I come up with anything worthy of suggestion I'll certainly let you know.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
Just mention everything. "Worthy" is relative term lol. Mine was buried in mudhole from hell. Front of vehicle was pushing a ton of mud. My 4500# winch simply stalled out. So we hooked snatch block to a tree and put end on top tube. We were both amazed.
No kidding, I bet you were real nervous doing it!
Reactions: Delton
I would post a drawing of what I had in mind, but @sharp would complain. He doesn't like my drawings.
I like your drawings just fine, sharp will be ok.
Reactions: sharp
