P700 Windshield Rubber Strip
Lynn1130
Lynn1130
126
171
Phoenix, AZ
I lost one side of the rubber strip that helps seal the windshield to the side post. does anyone have an idea of where I can buy replacement striping?
IMG 0521
43,292
I'd bet NAPA and such has it in bulk. Maybe a body shop too.
Reactions: swsebek
popeye
popeye
3,275
14,644
kapowsin, Wa
Hi. I lost one too. I took the other one off and still probably have it thrown in the barn somewhere. Not sure if this is would work but I would probably give it a shot if I was looking to replace. 6 ft for 14.95
Moose UTV Windshield Trim Kit - 2317-0164 ATV & UTV - Dennis Kirk, Inc.
I don't think that stuff will seal right, it would be better than nothing but the sealing bulb is straight, when the one on the windshield is a side bulb, my phone isn't allowing me to attach the link right now but search side bulb trim in Amazon and eBay it pulls up multiple options. Along with any decent auto parts store can sell it to you by the foot
Sent from my XT1565 using Tapatalk
jawquin
jawquin
299
653
Indiana
Awesome and thanks. That's right tmjm. I should have studied and thought before post or looked at old one. Scratch the last post. I bet a side bulb can be found here reasonable. Maybe?
Buy EPDM Rubber Seals - Free Shipping over $50 | Zoro.com
Reactions: popeye
jawquin
jawquin
299
653
Indiana
But who needs 25 feet of EPDM?
I do. I need 100 feet. Then I could help lots of others out. I lost one, you lost one and I bet others have lost one. You can buy this stuff from 1 ft -250 ft rolls. I can send you the used one I have that's cut to length.
allgm1
allgm1
1,049
1,484
New Hampshire
I think the door seal on a late 70's early 80's chevy pick up is the same thing. I lost one also, need to get another one before snow flies.
jawquin
jawquin
299
653
Indiana
Lynn1130 and allgm1, I ordered 4 ft of material which should make 3 to test with. They are 14.5 inches long. I will yet you know if it's a good solution and will send you one if it is. Thanks
Reactions: swsebek
swsebek
swsebek
2,854
5,835
pa
Seems you guys all have the same windshield and appear to like it.
May I ask what shield and do you recommend it.other than seal replacement.
I'm asking cause I have made my own 3 times now.Im tired of lexan and the scratch glare.
Reactions: jawquin
T
trapperm
31
34
Bemidji Minnesota
I lost one too. . . I ended up cutting the one I had in half and putting it on the other side. Will be interesting to see how the aftermarket stuff works.
I have the 2 piece Honda windshield. Its great except that I wish it would open a bit further. The scratch resistance is "ok" but Im currently looking through a scratch that was my fault during removal one day.
Trap
Reactions: jawquin and swsebek
allgm1
allgm1
1,049
1,484
New Hampshire
honda 2 piece here. I never wipe mine, a hose and a truck washing brush with lots of soapy water, then rinse. Like @trapperm , I too have a scratch that was my fault.
Reactions: swsebek and jawquin
jawquin
jawquin
299
653
Indiana
I have bought 3 windshields. 1st one was a Split Honda hardcoat for 700. 2nd was a lower cost one for 500. 3rd was a Split Honda hardcoat for 1000. The Honda Split Hardcoat is pretty good. Nothing beats an Automotive glass style as far as durability though I don't see those offered in split and I like convertible changeable stuff. There is one that keeps catching my eye I would like to try and that's a Superatv flip style. Best wishes and there's good one's out there.
Reactions: swsebek
Lynn1130
Lynn1130
126
171
Phoenix, AZ
Glank
Glank
100
340
I know this thread is old, but post a question. I keep losing my side seals. It's a running joke with my friend because I call them on the radio to stop because I keep losing my rubbers. I have the hard coat Honda OEM split windshield. I usual lose the small lower windshield seals, but ironically, I've found them every time. The tree branches love to scrape them off. Last weekend the snow was wet and heavy so the branches were horrible. I lost the lower on the way in, but found it on the way out. But, at some point on the trip, I lost an upper. How the heck does that even happen, and without noticing it.
Anyway, my question is, do I even need to have the side seals on if I don't have a fully enclosed cab? It does appear that the sides of the windshield come in contact with the ROPS, so I'm assuming they are only there for air intrusion if you have a fully enclosed cab????
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Little late but I used clear silicone to make mine stay on.
Reactions: Glank
Glock21user
Glock21user
" Nothing succeeds like excess "
1,815
9,039
Livingston county, Mi.
I lost mine pretty early in and never replaced them.
Didn't care because if I wanted to sit in a sealed cab either my truck or my jeep would be chosen not a SxS.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
I don't think it is to keep it sealed it's to keep the plastic from banging together when it vibrates.
Reactions: Glock21user
