P1000m5 wiring diagram for 2017 1000-5 LE
Markeabe
7
7
Us
looking for info as to what wire under the hood goes to the tail lights on a 2017 1000-5 LE. i want to use this option to power the dash courtesy lights i have installed
Reactions: sharp
Neohio
Neohio
Beast of the East
14,465
72,308
Painesville Ohio
There is an accessory wire under hood on the fuse panel that is ignition controlled.
If you want the tail light specifically, you can tap into it at the back of the switch.
Edit: brown at headlight switch for all 17’s except LE.
Edit2: looking at my wiring diagram, I am not quite sure where the LE gets tail light signal from.
Reactions: sharp
