P1000 Yet another Snorkle
faronij
faronij
17
58
loxahatchee FL
Didn't like anything in the aftermarket so after looking through others ideas.... took alittle inspiration from all of them. 2"abs pipe and fittings topped off with a Warrior Riser. Had to ditch the middle seat belt in order to make this happen and make a few cuts to fit the piping. Also made a drain in the lowest part of the pipe and ran some clean tubing on it for easy viewing if water does ever get in there( yes drain is capped)
20201121 135525
20201121 135541
20201121 123159
20201121 130602
20201121 163627
69,281
Didn't like anything in the aftermarket so after looking through others ideas.... took alittle inspiration from all of them. 2"abs pipe and fittings topped off with a Warrior Riser. Had to ditch the middle seat belt in order to make this happen and make a few cuts to fit the piping. Also made a drain in the lowest part of the pipe and ran some clean tubing on it for easy viewing if water does ever get in there( yes drain is capped)View attachment 236801
View attachment 236802View attachment 236803View attachment 236804View attachment 236805
Looks great! I seriously considered doing the same but if you ride in much dust it gets dirty very fast. Id definitely run a pre-filter in that location.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Looks good. Well done!
JenElio
JenElio
75,058
677,174
Loxahatchee, florida
That's sweet man! Looks good!!
Welcome to the forum!!
JenElio
JenElio
75,058
677,174
So do I. West side of Temple off Pratt. I have a mobility impaired permit (AMP) so I'm able to go into alot of places others are not
Cool, I'm on north end of North Lake/Grapeview
That (AMP) permit, is that for Corbett? I just have the management stamp. But I ride a few local empty lots and every now n then I got out towards the end of 60th and 200th area
faronij
faronij
17
58
loxahatchee FL
I can use it in Corbett yes. Use to ride 200 also. Been riding in lox for 25 years. Its gone to crap. Sold all the atvs for that reason. Hit me up sometime. We can wrench on the Hondas
JenElio
JenElio
75,058
677,174
Yeah I've heard stories of how it "used to be" out here. I've only been here for about 12 yrs. Always looking for new spots and people to ride with.
