P500 Zaleski’s P500
Zaleski
Zaleski
67
176
Ohio
Figured I would start a thread to document my build.
This week I mocked up my bed to accommodate the side mount toolbox I got
A7A17BF2 A719 4D64 9804 798DDE919FB8
7150CBE2 324D 4C1A A90F B21E7D360F3F
Used 3/4” birch plywood as the bed, and 2x12 for the sides and tailgate. Kicking back and forth ideas now, most likely am going to do a diy spray in bed liner on all the wood, and debating wether to use the Honda rack clamps, or to just drill through the rack and bolt to it. Also considering using Simpson strong tie gussets angle brackets to strengthen my set up- credit for idea of this setup to Appalachian mountain riders on YouTube.
Zaleski
Zaleski
67
176
Ohio
Got a little further on the box build. I ended up using Simpson strong tie brackets to beef this thing up since i’m Planning on mounting the spare tire to the rear, I want it to be solid.
4B7417B8 E366 4AD2 BED4 688DD7666A7D
977D6897 B920 43D5 B8E9 DD224A758282
B5CA3155 ACEB 4940 869B 980B537BFF6C
Now I just need to do some sanding and decide on bedliner or do a wood sealer & paint it black, leaning towards diy spray on bedliner. Line x quoted me $400 to spray it (yikes). Still waiting on my Honda cargo tray clamps to arrive
154,855
View attachment 162867 View attachment 162866 View attachment 162865 View attachment 162866 View attachment 162867
What are the two straps in the center doing?
Mudder
Mudder
NTC Ambassador of Walls
11,281
83,656
Is the spare tire mount off the rear? Maybe some bracket supports at the top corners? Thru bolts/nuts vs screws. Especially for the hard bumps.
72DE5B8D 6D6F 4F75 A016 79643FB13277
JCart
JCart
897
2,024
Kamloops, BC Canada.
Looking awesome, really nice work. Only thing I’d suggest is a drain hole, on mine albeit a plastic containment tray with 5” sides, I drilled a 1/2” hole in one corner and installed a boat plug, works perfect. Surprising how much mud, dust and debris will get in there.
Cheers,
j
Zaleski
Zaleski
67
176
Ohio
Cheers,
j
Thanks! Yeah that’s a good idea to plug with the boat plug, gonna wait to drill the hole or 2 until I see if there is a low point naturally once it’s all mounted up
Mudder
Mudder
11,281
83,656
Cheers,
j
Had a sheet metal pan insert in my old one, amazing how much mud, twigs and leaves find their way back there. Makes a tornado of debris with a power washer. LOL. Half of the fun with a P500 is DIY mods for sure.
71E653FF 08E9 4570 AC23 75268BA4C974
JCart
JCart
897
2,024
Ya after I noted my suggestion I realized the front is open to the aluminum box.... Yeesh sorry. Regardless looks awesome and it’ll probably drain fine on it’s own.
Mudder
Mudder
11,281
83,656
That’s a really good looking rig!
Thanks, some of the best mods are not seen, (PS, Locker, Skids). You are smart to try some quick clamps for easy removal of the box as mud will collect underneath. For final finish, stain and spar varnish, paint, or thin diamond plate skin???
Zaleski
Zaleski
67
176
Ohio
I was on fence about painting/staining then sealing, or bedlining. I ended up ordering raptor bedliner yesterday, so we'll see how it works out. I really like the idea of the diamond plate skin, but just not confident enough I could make it look good
Reactions: fallrisk
Mudder
Mudder
11,281
83,656
Sounds good, was just thinking of the thin diamond plate I saw at Lowes the other day, cuts with jig saw. I used the tool box legs for side trim on mine.
EDE1B7BB 6FAE 435C ADE8 416A473C5F50 Image
