P700 08z08-hl5-a00 hookup help for switch panel
bassadict69
30
20
Benton, La
I just bought this harness hoping to make it easy to wire up my switch panel and lightbar. I am a wiring dummy, just so you know!
I want my switch panel to be on only when the key is on. Do I simply unwrap one leg of this harness that has both pos and neg and run them to the switch panel?
NewHere2
NewHere2
Village Idiot In Training
36,732
310,761
High Plains of SD
Can you post a pic of the harness ?
What year is your machine ?
bassadict69
30
20
Benton, La
I am not opposed to buying this other harness... I am just looking for a simple way to hook up power to my switch panel, then to my lightbar and later a backup light, etc. If this other harness allows that, I will purchase...
Blueridgesxs
5
32
Boone, NC
Why do you need another panel if you have extra spots for rocker switches on dash? Total newb here
64,288
I think what you have will work. Plug it in and put a test light to it.
Because it is not nearly enough places. a panel makes it look nice.
bassadict69
30
20
Benton, La
So, with either of these harnesses, do I still need the fuse panel? How does that get wired in, from this harness?
NewHere2
NewHere2
36,732
310,761
High Plains of SD
I can’t locate the Honda part number you posted. Is it just the harness and no fuse box ?
What year is that harness for ?
If possible, post a pic of it.
bassadict69
30
20
Benton, La
64,288
Ya, thats what I thought it was.
one of those is a key-on hot wire.
Some are grounds.. no clue what the other ones do.
