![PaulF](/data/avatars/m/18/18905.jpg?1602618875)
There is no such thing as code 83 for any of the systems.code was 83 on i4wd light flashing
IF the i4WD light and oil light are both on with the engine running, you have no oil pressure (or the sender is not connected and it appears to the computer you have no oil pressure). If that is the case, the ECU will not let the clutches engage because they use engine oil pressure and to the ECU, you have none.Now buggy won’t go in gear.
All gears are like in neutral.
A - in gear selection box not flashing and then it goes a 2 again not flashing. i4wd light on and red oil light.
I suspect (like almost every one else that see the dash go nuts) that you have a connector issue...
- Lose or corroded battery cables.
- Lose or corroded ground connections (there are 3 of these, check them all).
- A plug not fully connected together.
- A wire improperly inserted into a plug.
It is hard to explain what a dash does so if you want additional help, it is probably better to post a video of the dash from key off, key on for 3 seconds and then running for as long as it takes all the lights and indicators to cycle through their codes.
DO NOT post a 3 second video showing the dash flashing, it does not tell us anything useful. We need to see everything from key off to the end of the flashing cycle to glean anything useful. And make sure the video is in focus.
