P1000m5 Bad_Bowtie's Boring Budget Build
dlmjr9
dlmjr9
9
11
Fuquay Varina, NC
View attachment 174811 View attachment 174812
I put my door in a couple of days ago. I used the same 2 orange boxes u did plus 1 bigger metal ammo can from rural king. Still got room for a couple of small dry bags on top of the orange boxes. Had trim A slot in the door frame to get the bigger box in.
What size is the metal ammo can?
Did you add anything to the bottom of the storage area to hold everything?
Reactions: TripleB and Russ989
TripleB
TripleB
12,109
103,201
Caryville, Tennessee
Reactions: Russ989 and Mudwing
TripleB
TripleB
12,109
103,201
Wh
Might I ask why you are using two different kind (plastic and metal)?
That was the only combo I could make fit. U could fit 2 metal. I've not done the math on which way u actually have more storage but I liked the 3 boxes better. I put 4 ponchos in dry bags and cram them on top and around boxes. Keeps everything tight.
Reactions: JTW and HondaRed16
HondaRed16
HondaRed16
257
500
Arizona
That was the only combo I could make fit. U could fit 2 metal. I've not done the math on which way u actual have more storage but I liked the 3 boxes better. I put 4 ponchos in dry bags and cram them on top and around boxes. Keeps everything tight.
Makes sense :D
Thank you,
57,526
I hate to say it but I didn't get any. We rode pretty much non stop for about 7 hours. Usually my co-pilot takes tons of pics, but she had to work yesterday.
I will say this, I just thought the P1000 was capable before. After adding the Arms and 30s, I'm thoroughly impressed. I followed 2 new X2 Wolverines, 1 of which is the new X-TR package. Places where they would struggle, I had no trouble whatsoever.
Did you notice your rears rubbing on that ride? Trying not to add the rear SATV arms just yet....
57,526
I dont recall having any trouble with rubbing before the rear arms. I do have a small spacer lift but they should still work fine.
Cool, I can throw a little more preload in if I need to until I can get around to picking up the rears. Thanks brother
TripleB
TripleB
12,109
103,201
Just a heads up, those plastic orange boxes had a little water in the from a 70 mile ride last sunday. They must flex a little when moving and let a little water in. It wasn't much but it should be zero. I'm gonna try 2 big metal boxes next. I'm gonna put my first aid kit in a dry bag and 3 ponchos in small dry bags to take up the dead space. My metal box had zero water in it.
Bad_bowtie
Bad_bowtie
Huge member
2,500
15,151
East Tennessee
Good feedback. I'm gonna use them for now but if I have any trouble I'll definitely use the metal ones.
Reactions: Russ989 and TripleB
208,135
My rear always rubs on the seat on a ride? Get the backs, makes negotiating obstacles same as front.
Reactions: Isaiah and Russ989
Bad_bowtie
Bad_bowtie
Huge member
2,500
15,151
East Tennessee
Giant box awaiting me when I got in from work. Looks like it's time to retire the aluminum skid and try some plastic.
20200415 192532
