Big Red starters
butzy
Had same issues as other big red muv owners. Starter was sluggish last winter and this summer it died. Starter magnets were cashed. Couldnt find aftermarket starter anywhere. Had to order new starter. Waiting for it now.
T
turbodog
Thanks to everyone for helping me figure out why our 2 '09 models crank like turds even with new dual batteries. Both units had cracked magnets and loose magnets. Looks like honda did not use enough glue on the magnets. I've got a brother that's a high-profile attorney. Anyone up for a class action suit?
Reactions: IndianaMike
T
turbodog
7455 4997883d98aa4f16ca4c876b7faca906
7454 5102b8efaa512ed362a7378c7d6e4282
7453 c4f394f3df54fd1f4646f32f54e0115c
64,288
Glad you found the issue. 6 years on a starter is fairly good and most likely past Honda's realistic expectations.
Hope u get it back up and running soon. Thanks for sharing.
T
turbodog
Can't say this makes much sense. Both units have cranked poorly since they were brand new. Also... we have other atvs that are 20+ years old on original starters.
I understand the disappointment, my 12 year old Honda foreman still has a strong starter. I would also expect the same on my Honda SXS.
Reactions: ohanacreek
T
turbodog
I guess my plan now is to proceed with the new starters (which are a different design). If it fails... I will have to setup some additional forced-air cooling that is directed onto the starter.
madmech
Tennessee
We are having the starter problem with our 2011 Big Red. My question is: how did you get to the starter? I'm a mechanic by trade and this has got me stumped. Everything is welded together. I'm 70 and this is NOT fun.
T
turbodog
remove both seats
remove passenger seat frame, 3 bolts
remove center plastic, 6 phillips screws
remove passenger plastic, several phillips screws
(might have to use impact driver to remove some of these screws)
this will give you access to starter
(2) 10mm (I think) bolts hold starter on. I used a normal socket for the one nearest the passenger side of the utv. I used a crowfoot for the other one.
Get under the unit with your feet poking out the driver side and head under the passenger. Grasp starter with your left hand, wiggle, twist, and slide it forward.
(you can't get a good angle with your right hand. we did 2 of these and had MUCH better luck using our left hand)
Once out, remove the positive cable.
straighten the lug on the cable end. the new starter should have terminal in a different place than the old one...
Oil new o-ring.
Slide starter in
reinstall 2 bolts
connect positive wire... might be tight.
Should take about 30-45 mins.
Starter can take a while to wiggle out... depends on how dry the o-ring is.
madmech
Tennessee
remove both seats
Oil new o-ring.
Slide starter in
reinstall 2 bolts
Not quite that easy on the 2011. I'd done all that and still couldn't reach it with my hand, left or right. Plus the bottom plate is welded and there is plastic sheathing everywhere. Ain't no way to reach that ---- starter from the top or from underneath. Blood pressure is sky high right now.
Reactions: bobbyhill
gnedinok
gnedinok
24
25
Wellston, OK
  2. Big Red
anyone tried one of the EMS Global starters listed on E-bay @104.99 + free shipping? Says they have sold 55 of them. They list the correct Honda #'s that it replaces. Just wondering, G
gnedinok
gnedinok
24
25
Wellston, OK
  2. Big Red
Just saw a review of the HL1-305 sold by Central FL Power sports on e-bay. Copied the review. Then I saw the same review on another Honda dealerships listing. Gotta wonder.
Junk
Broke first time out garbage armiture and brush setup its plastic.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I think they changed them on the Pioneer because you never hear about people having problems with them. Since the two vehicles share essentially the same drivetrain, I wonder if the Pioneer starter can be adapted to the Big Red?
gnedinok
gnedinok
24
25
Wellston, OK
  2. Big Red
Will someone chime in on this question! Thanks, G
Reactions: Tflynn
K
KerXR75
12
Oklahoma
  2. Big Red
remove both seats
Oil new o-ring.
Slide starter in
reinstall 2 bolts
Reno58
Reno58
53
74
Middle TN
Bought an '09 Big Red new in '10. Used mostly for hunting rig and some back woods riding until TN passed law allowing sxs on secondary low speed roads. Got mine tagged and necessary upgrades to meet laws and started putting miles on - that was in 2017. At 675 miles came in from a long night ride, pulled up to my garage, shut it off and would not restart.
After checking determined was starter. Called Honda dealer and was informed that was common prob with '09 to I believe '11. Magnets delammed from housing. They said Honda had in fact replaced several at no charge but that was several years ago. They checked with Honda and of course was told too old, no dice.
Checked Honda replacement, upgraded style, was gonna be $400! Tried to get rebuilt but was told couldn't re-attach magnets to housing.
Checked around and bought aftermarket starter for $150 and worked fine until I traded in on '17 Pioneer.
Long story, but my understanding is Honda was aware of bad starter design but I discovered it a few years too late.
My life's story.
Reactions: Mudwing
