P700m4 Coolant Leaking from hose fitting
joejoebear88
Hi guys! My 2015 is leaking coolant from a hose nipple on the water pump. I don’t see a loose hose that would go to it. Anyone have any insight? Thanks in advance.
64,288
Hi, Welcome to the club.
Its the weep hole. It is designed to leak but if it is leaking to where it is dripping that means the water pump seal is bad.
Depending on the leak. You should consider replacing it.
Its not too hard, but it was a PITA to do.
I'll find a link and post in a few of when I did mine.
here is a photo gallery - 700 Water Pump Replacement
I dont think I did a write up on it.
Reactions: swsebek and Mudwing
