Honda Factory Photo Tour
admin
admin
Your club! I just turn it on!
317
Here is a YouTube photo slideshow of the Honda Factory producing the Pioneer. It is kool to see it being mass produced this way down an assembly line. check out all the different stages it went through to produce the final product.
greenatv
greenatv
127
31
Its kool to see a high tech assembly line running those blue trolleys. They can probably be programmed to go anywhere in the factory floor.
Swamper
140
15
Take a close look at how modular this machine is. The main chassis is very simple with sub-frames being bolted on. I can easily see where they can "Pioneer" several variants from this basic chassis. I'd bet future variants will utilize many of the same components as they've done with the motorcycle line. Competition is here!!
N
nutmeg
30
ya. you can see them putting it together in sections. it should make it more mod'able too. going to be fun.
64,613
Very nice, You can almost see it being built from start to finish. It looks like if you are in a wreck you can just replace the front. Thats in the long run I'm sure as I know I will more then likely wreck mine sooner or later.
Swamper
140
15
Who agrees they will likely put half of a Honda Fit engine in one? They used the Fit engine in the Honda outboard and made a twin cylinder variant powering several 50 hp motorcycles now. Cylinders are tilted making it easy to stuff into one of these. And it already has an auto transmission. I'd says its already being tested!
