P500 P520 Stock Wheel Sizes
Amitchellr
Amitchellr
67
278
53
Just took the stock wheels off the P520 to replace with 12x7 5+2 itp steel wheels and new tires. I noticed the front stock wheel was stamped 12x6.0AT and the rear stock wheel 12x7.5AT. I am new to all this and the research suggested the ITP wheels would be the direct replacement. Can someone help me understand what the stock wheel stamps mean and of If the new wheels will work. Thanks in advance for all the help.
front wheel
608CA545 C502 4248 8D78 8AA05D8C7E14
rear wheel
DE5CB495 1DA9 4602 8F0B 83DA70802B03
208,029
front wheel
rear wheel
12 Rim size X 6 inside of bead seat to outside of bead seat
Reactions: 500oneer
208,029
Thank you so 12x7 5+2 should work on all four corners.
I would think so, but you will probably need wheel spacers to make front and rear track the same width. The distance from the surface to surface of the rear wheel mating surfaces are usually 2 inches narrower than the front
Amitchellr
Amitchellr
67
278
53
So if I do 25x8 tires in front and 25x10 in back it should align
208,029
Get tires out of your head and think about bare rim measurements outside to outside front and rear. Your not going to correct track width with tire sizes.
