P700 Stretched Oil Pump Chain
N
Nevinst
New Mexico
Is it common at all for the oil pump chain on a 2016 Pioneer 700 (with 3000+ hrs) to stretch and jump the sprocket? My machine was purchased used and burned a lot of oil when I got it and until I rebuilt the top end. It is likely that it received some abuse during the period before I owned it. About 300 miles after my top end work, the timing chain slipped. When I tore it down I discovered what looks to be damage to the timing chain that was caused by an extremely loose oil chain which looks to have jumped the sprocket and contacted the timing chain, damaging one of the timing chain links, causing it to slip out of time. Upon looking further it seems that the oil pump chain had been so loose for so long that it actually wore against the oil pump housing enough to wear completely through the housing. I cannot imagine what sort of abuse/wear could have occurred to cause the oil pump chain to stretch as far (and last as long) as it has. Is this a common thing? I can't seem to find much on the internet or in this forum on the matter.
Is there anything else in particular I need to look at before I start replacing damaged components and putting it back together?
  • Sad
Reactions: Scoop and Rupert
K
Kite
Tishomingo Okla
I’m going through this same deal. Is there anyway you can tell me more ? lol
  • Haha
  • Sad
Reactions: Remington and Scoop
highpocket74
highpocket74
1,865
5,967
Kinder, Louisiana
www.10-80dirtsports.com
I think I have suffered the same fate as you.
My 2016 was overhauled and running great after a badly loose timing chain was replaced. Then withing 100 miles the machine stopped moving forward or reverse. I've spent enough money on this machine already with rehab after an abusive previous owner. Getting tired of spending more but now I'm too far in to quit it seems.
  • Sad
Reactions: Buggyman and Scoop
Hello_Darkness
Hello_Darkness
34
150
Just to the right of nowhere
Even new the pump chains aren't tight
If it indeed has over 3000 hrs, then I'd say it's just worn out from use
109,544
What rig do you have?
Welcome from Michigan BTW
Reactions: Buggyman
109,544
Prob why he hasnt been on the forum 3 days after that post 4 yrs ago lol.
Prob sold it and bought a Poo Poo🤣
Reactions: Buggyman
