System-One-Rack "Base" ( T-slots accept 5/16 Stove Bolts ) Modified to fit on P520.
Started with 2x2x3/16 Alum.Angle as the Base <> Along both sides and across front of the InsideTop Edge of the Box ( welded in the front corners along with welded tab in rear corners to accommodates rear attachment bolts )
Attached to 3 Honda OEM welded in nuts <>10mm Wrench <> Remove 3 bolts <> Comes Off as a UNIT.
Uesd Only 5/16 <> Stainless Stove Bolts <> Washers <> Locknuts. ( Requires <> 1 <> 1/2 inch wrench or ratchet and socket )
Hard Plastic ( Tonneau Cover ) shelf fits in 2 locations <> Top of OEM P520 Box <> Moved UP <>Top of the added Sides or Removed ( loosen 2 nuts )
Fuel can Mounts <> Moved or Removed ( loosen 3 nuts)
Alum. Traction ramp above Tailgate <> ( loosen 2 Nuts )
Unlimited Versatility and storage options
Many Tie Down locations added.
When the requirements of the Load changes <> plenty of options
Soft Tonneau for the Dust or Rain is yet to be finished.
Pictures tell it best <> to Aid understanding the description.<> along with a few storage boxes for show and tell ideas.
![20220814 175855 20220814 175855](https://hondasxs.com/data/attachments/348/348176-87f46e6a89c070d37be2432f9805ef35.jpg)
![20220814 164627 20220814 164627](https://hondasxs.com/data/attachments/348/348162-36f22c8bf125855d1337bc5007f643b9.jpg)
![20220814 164639 20220814 164639](https://hondasxs.com/data/attachments/348/348163-2f90816a2beec98cf16ecbc373629142.jpg)
![20220814 164654 20220814 164654](https://hondasxs.com/data/attachments/348/348164-a59afb3cd650f08dddb4a64529e7512d.jpg)
![20220814 164900 20220814 164900](https://hondasxs.com/data/attachments/348/348165-794911169b02c6b2cc78352fcae40e1b.jpg)
![20220814 164920 20220814 164920](https://hondasxs.com/data/attachments/348/348166-785b53b6e0065e56e2bc2f57db7fec3a.jpg)
![20220814 165025 20220814 165025](https://hondasxs.com/data/attachments/348/348167-782aac3341d8b72ff03a3b311888f3c7.jpg)
![20220814 165405 20220814 165405](https://hondasxs.com/data/attachments/348/348168-bf540cd87c6d942dcf25216fb3f01c2f.jpg)
![20220814 165604 20220814 165604](https://hondasxs.com/data/attachments/348/348169-35bef44e2ec69b696e2f9b6b7ecdcff0.jpg)
![20220814 165821 20220814 165821](https://hondasxs.com/data/attachments/348/348170-a2f741ae497e0a0f3dede277647083cf.jpg)
![20220814 172435 20220814 172435](https://hondasxs.com/data/attachments/348/348171-1ea1800d065eacc7d9e562ce40bbf3e9.jpg)
![20220814 172452 20220814 172452](https://hondasxs.com/data/attachments/348/348172-dd2ecbb4c0a8e4db655d0c09d6260398.jpg)
![20220814 172645 20220814 172645](https://hondasxs.com/data/attachments/348/348173-7aabebe3c1b0f599f31634a31b6eabf4.jpg)
![20220814 172748 20220814 172748](https://hondasxs.com/data/attachments/348/348174-7c232bd8b901aa63f39b71f0ec54fbb3.jpg)
![20220814 175824 20220814 175824](https://hondasxs.com/data/attachments/348/348175-476860f535e4af54c70d3cf1848bf57a.jpg)
