P1000m5 Truck tires
Sport20
Newfoundland canada
Hey
Anyone every use 14" truck tires on sxs . Was thinking about trying bf goodrich truck tires
Screenshot 20240218 053916 Messenger
Buggyman
Buggyman
36,278
308,300
ne. ohio
Hey
Welcome to the forum. I think most are running 15" but a quick search using the search bar above will provide enough info and opinions to make your head spin for days. good luck on your search and post pics of whatever you decide on.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I have been running some Maxxis Buckshot II 27x8.5x14 and have been happy so far. I have a full set of Deluxe 14" front rims all the way around. They have been great as we ride alot of desert roads and then I can jump back on the paved highway to get back home. I have found that I have lost a little ground clearance that my stock tires, but that is my only complaint with them. They were a little stiffer ride as I was running 16 psi, but I moved down to 10 and I like the ride better. The nice thing is I don't think you could ever were them out.
5,146
23,280
Wanting a high mile tire, I tried the BFG K02 LT tire but they rode considerably harsher than an OHV tire, so when I cut a sidewall (entirely my fault) I went to the BFG KM3 OHV specific tire and it rides noticeably softer with the same tire pressures. A LT tire will generally last a lot longer than an OHV tire. You picks yer poison.
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
I went with the GBC Parallax because they have an all terrain tread and a 10 ply sidewall with a UTV weight rating. At 10 PSI they look good and drive nice. I'm looking forward to getting them in the dirt. They are a 31x10x15 so they might be a bit big for most but they start at a 29" which would likely fit a stock machine or machine with offset front arms. Shown below are the new 31s vs my old 30s. I was really searching for a lighter tire and these came out to be about 8lbs lighter than my previous setup at 55lbs per corner
1000006233 1000006249
someguy1313
someguy1313
174
383
SouthEast
View attachment 418735 View attachment 418736
keep us posted! I see everyone loves LT tires, but weight is a real thing for some of them
looking at the Forceum MT 08 PLUS Mud Terrain LT27X8.50R14 95Q C Light Truck Tire​
haven't figured out weight yet
  • Haha
Reactions: Remington and ChadD
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
I was very interested in those but they don't come in a 30 or 31 so I kept looking
Reactions: ChadD
Robobrainiac
Robobrainiac
2,475
8,664
What lift and arms do you use and how well does it clear the 31?
Robobrainiac
Robobrainiac
2,475
8,664
Interco makes the Sniper 920 which is a UTV rated DOT tire.
When I purchased my 30s I was able to snag them on sale @ around $150 each.
Reactions: someguy1313
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
Superatv arms front and rear with Stage 4 Elkas. The front should be fine with the grill trimmed under the headlights. The rear will likely still rub the rear cage support and under the doors. With 2 guys up front I did alright with 30s. And I'm only a little bigger now. The lighter and softer sidewall 31s seem like a good compromise. Old tires were 30x9.5r14 EFX motovators. New are 31x10.5r15 GBC parallax. I'm pretty much coil bound and into to bumper on the front shocks as shown. In the rear I have about 1/2" before the bumper. I've been alright with the rear rub the las few years. The soft ride with worth a little scrub vs a stiffer spring and taller jounce bumper
1000006234 1000006249 1000006237
Robobrainiac
Robobrainiac
2,475
8,664
View attachment 419380 View attachment 419381 View attachment 419382
Awesome. It looks great!
Reactions: ChadD
StewB
StewB
683
3,169
St. Nick can go pound salt. St. Paddy rocks - he left me something on the porch.
1709928515642
27x9-14, 27x11-14 Sniper 920's.
Going to be a bit before I get them on my rig, but I'll try to follow up.
Will be swapping the OEM Bighorns for these. Cannot go to a bigger tire w/o chopping the ROPS to get into a low garage.
@Robobrainiac 👍
Will follow up.
Robobrainiac
Robobrainiac
2,475
8,664
@Robobrainiac 👍
Will follow up.
View attachment 420611 View attachment 420613
Super Awesome!
My projects always take forever. I just pulled my SuperATV Intimidators off yesterday and painted my bead lock rings today.
IMG 1410 IMG 1411
