What size tires do you plan to run on your Honda Pioneer 1000?
Thanks.
Poll viewable on the website!
Thanks.
Just wondering, cause I have no experience with putting different sized tires on stuff, does radically changing the tire size change gearing and if so how? Also, does it void your warranty?? ThanksWhat size tires do you plan to run on your Honda Pioneer 1000?
Thanks.
Ok thought that was prolly the case .May keep some mud tires on 12 in rimsYa they will.
Or at least my oem Rincon wheels fit my P700. P1k should have the same lug pattern as the P7 so I would say yes, they will.
Wasn't sure but did we decide a true to size 30 x 10 would work without a liftI'm gonna go with some 29" bighorns.
Ya they will.
Or at least my oem Rincon wheels fit my P700. P1k has the same lug pattern as the P7 so I would say yes, they will.
I suppose so, guess it is typical of how Honda overbuilt much of the machines to start with that as they evolve the parts are already designed to handle it.The same size studs are used on small cars that weigh 3500lbs, wouldn't think it would need to change.
