P1000m3 Wheel Bearing Replacement
  • Thread starter Mountain Whiskey
  • Start date
Mountain Whiskey
Mountain Whiskey
27
81
USA
This may have been talked about but I don't see it. I tried YouTube University but not much there. The beater I was taken to the cleaners for, looks like it has a bad wheel bearing among the other things I have found. Do I need to take the hub off and press this bearing?
109,541
This may have been talked about but I don't see it. I tried LUBE TUBE University but not much there. The beater I as taken to the cleaners for, looks like it has a bad wheel bearing among the other things I have found. Do I need to take the hub off and press this bearing?
Fixed it for ya😉
You need to use a press, not a puller to get that wheel barring out. Unless you have alot of blood pressure meds?
So where is the State called USA located in your Avitar ? Might want to fix that if you dont want that asked alot lol
Also, no pics from you of your rig since you joined. Its Rule #4 Pics Or It Didnt Happen!
Mountain Whiskey
Mountain Whiskey
27
81
USA
Fixed it for ya😉
The beater has been in my garage since I brought it up to Northern VA from the scammer dealer down in Galax VA. I'll get some pics when it sees daylight again.
Bayouownbeer
Bayouownbeer
790
1,096
Chauvin LA
P1K5Dave
P1K5Dave
2,192
8,229
Petoskey, MI
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
Can you press in/out the bearing without removing the hub with that kit? I've got to do some bearings in the Spring, so if this works well I'm going this route.
You have to remove either the lower a-arm or the ball joints to get the axle shaft out. I'd prefer to remove the knuckle and work on the bench. As I recall I removed the upper ball joint and the lower a-arm because the lower ball joint but is a pain with the axle in place
Bayouownbeer
Bayouownbeer
790
1,096
Chauvin LA
Yes but you have to remove the axle the axle passes through the bearing. I just removed the hub. To get the axle out it will be half way to removing the hub / knuckle so you might as remove it to make the job easier.
Mountain Whiskey
Mountain Whiskey
27
81
USA
Yes, I figured I would try this tool before taking the hub up to the shop. I know I have one somewhere.
I can see getting frustrated trying to find it and going to the shop anyway. That is a sure fire way to find a missing tool. It will be practically waving a flag at me after a shop trip.
  • Haha
Reactions: CID
P1K5Dave
P1K5Dave
2,192
8,229
Petoskey, MI
Seems like I remember the fastest way to remove front axles was to drop the upper a arm at the frame and swing the hub down and out of the way. Probably dropped the tie rod as well. The rears, you can half drop and swing them out.
I may try to do it this way, especially on the fronts if I can.
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
Do you know if this kit is large enough for like an F250?
You could probably make it work but it won't be ideal if you have rust. I've done 1/2 ton axles and smaller joints with mine for years
Bayouownbeer
Bayouownbeer
790
1,096
Chauvin LA
Not positive but I believe so it has a lot of adaptors. Check out the reviews that may be discussed
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
I wasn't worried about the adapter sizes. The press fit on the bigger ball joints might be better than the cheap threads on that press. I've seen the threads fail and the c-clamp bend or break.
Like this one.
IMG 20240107 125134
EMAW
EMAW
Mama Tried!
3,137
39,532
Kansas
So……..….which W/bearing, front or rear?
Reactions: CID
