P1000 Front end loose? Sloppy steering?
I thought I’d share my quest to tighten up the front of Traveller. The 30” Roctanes have beat the front end over the past two years.
Here’s a vid of the slop before I started.
The passenger side steering rack has a bearing/bushing at the end.
This is a new one.
15bbb18e36ad229727366f6cd47d1d2c
This is the original installed.
3bc9c7f75b94a40ed03411a755ca052c
Here’s the old vs new. Not much difference.
A7e1545fabd11dc1ae2b85194c400d60
Remove the tires first. You can remove the boot and then the tie rod from the rack. Leave it attached to the knuckle. Remember that you’ll need new lock washers for the fasteners inside the boot. No pics at this time but I’ll get them later.
Turn the steering all the way so you expose the bushing.
38b86d112de305add2060ea3433dc9b6
I used a couple pics to remove them.
0a443114527e16107a4ab0f85843ff19
The new one pops in easily. There are two holes that need to line up with the two circles on the bushings. Apply some grease and then reassemble with a new lock washer. Make sure you punch the new washer so it locks the steering pieces together. The driver side doesn’t have this bushing.
Here’s the improvement.
Big change
After video two there was still some slop. Next was to adjust the gear mesh in the steering box.
28d5368c3a6b09538fa8a131dc69900f
Huge pain in the butt. Remove the two fasteners under the 12v accessory outlet in the cab. You’ll be able to access the steering box here. I don’t have the “special tool” to adjust so I removed the skid plate and used a ratchet and long extension. It took a 40mm socket to loosen the lock nut.
3d6579f9c9759c86a500d9a68c074f16
F669977bb1e3aad61a3be4265be774b4
Then from in the cab I could hold the lock nut with my hand and tighten the bolt. I have it half a round and it was too much so I backed off 1/4 turn. I knew it was too much because the steering wouldn’t return to center after taking it for a test drive.
This is the lock nut, bolt and spring removed
7c37b1d8291568d98824ec17f0a47eec
Df8ac29c136c088197302448cc550334
One more pic from the manual for reference
957ff9441c56c6054eaf977126f8b108
Also, I use zip ties for the tie rod boots and have so since 2000 miles ago and they have never leaked. I had to cut the metal bands off the inner part of the boot. If you wish to use new bands, don’t forget to order.
One other important thought. If you must field change a tie rod, the hardest part is cutting that metal band off without cutting the boot. The zip ties are no problem. I choose zip ties but you should choose what ever you’re comfortable with.
I’ve been putting this off, mine had too much play in the rack from @500miles.
I’m gonna have to do it now.
Reactions: ChadD and Rambo
