P700 HONDA PIONEER 700 2P/4P, 5 AMP ACC - ACCESSORY WIRING HARNESS & SWITCH KIT, 6 FT
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
For use with:
Honda 0SA30-HL3-100 Switch Plate/Volt Meter/Wire Harness
Welcome to Honda Pioneer Tech
KIT#33 951-HP700-AC05-180602, 5A ACCESSORY SWITCH & HARNESS KIT. CONSISTS OF: 5A ACC SWITCH, 18AWG 6' HARNESS WITH 2 POSITION PLUG, 11" ZIP TIES-QTY 3. APPLICATION: PIONEER 700 2P/4P ALL YEARS. MOUNTING LOCATION:ANY. KIT DOES NOT CONTAIN LIGHTS.
    • Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS must be installed in SXS before proceeding.
    • Harness is constructed with tough 18AWG wire, 6 foot in length, sheathed with flexible PVC tubing that is gas and oil resistant.
    • Harness Plug is a 2 Position Plug that will only fit either “AUX LIGHT” or “LIGHT BAR” 5 AMP plug in Accessory Fuse Box.
    • Harness Plug has splash proof gaskets installed on the base & plug
    • This is a 5 AMP rated harness that will support a 60 Watt device max.
    • ACC 5AMP switch is a Heavy Duty, 20 AMP, non-lit rocker that will plug directly into the Honda Switch Plate Accessory Harness.
    • Each harness is hand built and tested in the U.S.
    • Contains 11" zip ties, Qty. 3
    • Instruction sheet is included with kit
    • KIT DOES NOT CONTAIN LIGHTS
P1k 5a acc
