P1000 Max size I can put on my 2021 1000-5 without mods
Rtcole
Rtcole
35
138
Arkansas
I have 28-11&28-9 tires on my ride and was wondering what I could put on my ride without any modifications to the sxs. Also I was wondering if you like go with the same size on all 4 tires and how it would affect the handling? Thanks in advance.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
There are a great many posts on tire & wheel size. With 28's on a stock suspension, you are already at max (depending to some degree on actual tire size).
To get the same wheel size on all 4, some run 10's and use 1" spacers on the back to get the track the same. There is probably a tiny handling penalty, but I don't think much.
Rtcole
Rtcole
35
138
Arkansas
I forgot to mention that mine are also on 15 inch wheels.
473ED1E7 31B2 4568 9B48 7A102BBB3DB7 F6CFE507 D53E 40EC 8337 7568551BCF3C
108,186
What PSI should I have on the biggest tires I can run and what kinda oil should I be using??............
Whats the biggist size dome light can my stock electrical system handle? And what key on power source can hook it too without installing a second battery?….
