P1000m5 Wheel Offset/Tire Size to fit all 4 corners
AKTMW
AKTMW
82
115
Anchorage
Anyone know what the stock wheel offsets are? Looking to order a spare wheel/tire with offset that will fit both front and rear.
Anyone tried to see if fronts will fit the rear without interference? I had to go with a 4+3 on my Grizzly to get the wheel to clear front and rear. Don't want to make the machine too wide, but for a spare to get me out of the woods that's OK.
I'll have the dealer check when they fit up the 28's, but wanted to have an idea before I go talk to them on Tuesday. Wish we could go 30's without aftermarket parts, but have to wait for modified front A-arms it looks like? I'm thinking 10 wide in the front, 12 wide for the rear, or 12 wide all the way around if they fit.
TOOLOUD
TOOLOUD
261
155
Benton,La
Imo as long as you buy 4x137 IRS rims you should be fine. SRA rims would stick out and be too wide
267,227
Either the 6+1 or 5+2 offset on 14 x 7 rims. Only STI that I know of offers 6+1 offset in the 4x137 mm bolt pattern.
OEM is approximately 1.5" offset in front and 2" offset in rear if I recall correctly.
scott
scott
1,212
1,354
lyman, South Carolina
you sould be fine with a 5+2 offset for all four,, thats what most 700 owners go with.. If it is 2" rear you could do wheel spacer
Reactions: ohanacreek
What do you guys think about the MSA Kore 20? 3.5-3.5 is the off set. That's what I'm running on my p700 and like it.
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
I like those a lot would that be better or worse for a large tire being stuck out more? Is the rub more inside or outside? But yeah the MSA Kore20 may be the best looking rim I've looked at
Reactions: joeymt33
ChuckMagnet
I am thinking of running Deluxe rear wheels on all four corners with spacers on the rear. Does anyone think this is possible on a stock bike? Thanks!
