Amre2me2
Amre2me2 submitted a new Garage Item:
Amre2me2
Picked this one up a couple weeks ago. We also have the first 2018 P5 LE ordered that comes in. Hopefully before our lion season opens the middle of NOV.
So far, I've installed the following:
Odyssey duel battery with True isolator, 50" light bar, two LED rear lights, interior LED light, extended tailgate cables, Superwinch 4500 with in-dash switch, duel bilge fans and underseat insulation, Super ATV split windshield, foamed door hinges, fire extinguisher, OEM rear panel, single volt meter gauge with rocker switch to switch between batteries (you can see the switch below the gauge), rear view and side view mirrors, Ram phone and GPS mounts, seatbelt restrictor magnet exnayed, chainsaw mount, Erickson wheel chocks for trailer.
I'm currently fabing up a rear bumper that can be used with the bed lift without having to remove the bumper.
Also waiting on a lift kit for the 17 LEs.
Gonna run a couple of ducts from the fans into the floor of the cab for heaters.
Also going to run the Bighorn 2.0s to start the season and see how they do. I've run Ripsaws in the past in the snow and they were outstanding. Jury is out on these 2.0s still.
I've got several options for dog boxes. This is my large truck box. Holds 8-9 dogs but it's about 2" too long to be able to close the tailgate. Might cut off two inches from the back to make it fit or just use straps like the picture shows to keep it in place. I've also got two smaller boxes I've used In the past that fit in the bed perfectly. But they will only hold two dogs apiece.
View attachment 50307 View attachment 50306 View attachment 50305 View attachment 50304
Read more about this showcase item here...
E
elkguide
3,377
7,964
Vermont
SWEET!!!!!
Reactions: sharp
Amre2me2
Amre2me2
381
1,423
Colorado
Installed the Ricochet rock sliders today. Looking for some more conveyor belt material. Made some rear fender flares but didn't have enough for the fronts. Then a lift when someone makes a kit for the 17 LEs.
E
elkguide
3,377
7,964
Vermont
SWEET!!!!
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,184
27,679
Somereset, Texas
My rpck sliders should be here by the weekend. How did they fit with the factory LE skids? I've already bent my passenger side rocker tube
Reactions: sharp
Bowhunter
Bowhunter
52
124
Van Etten, NY
What side view mirrors are you running?
I like the looks of them, but haven't been able to locate them anywhere.
Reactions: sharp
