![Ericseabaugh](/data/avatars/m/51/51999.jpg?1655446831)
Ericseabaugh
After a little research it seems like a common problem and the solution is like $10 bucks so why not just do it and not worry about it. I had a question about the dpdt fan in/out rocker switch though. When the switch is in the middle position there isn't anything lite up. Is that normal. I figured the fan symbol would be lite up all the time but it's not. Now when you flip the switch either direction the fan symbol lights up along with which ever way you switch it to.I'm not sure.
These tail light's going out and switch LED's going out seemed to be linked to large relays like the Stinger or Cole.
I would to avoid voltage spikes.
This topic has not been discussed much.
