P700 Bashed skids and broken bolts
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Ok so I've never posted any repairs start to finish or added more than 3 pics to a message so here goes.
2016 new year ride in a first time sxs ride. What happens I center hang a rock that looks like mud on the trail. It broke 3 bolts on the front if the engine skid plate. The front of the skid plate folded in half backwards acting as a plow. I have since straightened it out multiple times because it CAKES with mud and I feel the engine vibrations were it is jam packed. So I changed the oil today and thought why not let's fix this. So I removed the engine skid plate with 3 broken bolts and
water running down one arm since the frame was full of water this is my frame. 20170814 165205
20170814 165150
Ok now to remove bolts. Tools I used :
1/2 cordless drill, 1/8 & 3/8 drill bit, centering punch, astro pneumatic nutsert kit. 20170814 165625
Center punched the holes
20170814 165955
Drilling the first bolt and it broke loose screwing through the frame and broke my 1/8 bit but that's ok $388 they have a lifetime warranty.. 20170814 170059 001
Drilled the second bolt and it doesn't budge so drill it with 3/8 bit and use my nutsert tool to install a threaded insert.
20170814 170951
20170814 165847 20170814 171040 20170814 171057
20170814 171137
A few hits with the LFH (little F'n hammer) on a couple 6x6's and the skids are as good as it's gonna get.
20170814 180235
3 M6 bolts plus the existing stock bolts and my skids reinstalled better than new.
20170814 181019 20170814 181025 20170814 165200
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Nice Job....Thanks for the info and pictures of the repair.... I hope to put all new skids on my P700 someday, but I'm about tapped out on money for mods for awhile...Thanks again for the info
Reactions: Mudwing
SundayRdr
SundayRdr
575
1,179
McMinville Tn
It's not as abrasion resistant, dont be tempted to the cheap side.
See I want a full skid front to rear but am a tight ass and don't want to buy something that doesn't work. I don't wanna spend $300-350 on plastic and spend 8 hours building one when I can buy bolt one for $550 ish. I like the skids @PioneerPete has but think he bought his.
UHMW is more durable than aluminum, slides over rocks and things aluminum would catch on, doesn't stick to mud like aluminum.
It's an engineered plastic designed for that type of use. It's used in mines and steel mills to line the conveyors.
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,656
Oshkosh, Wi
I spent the extra and bought UHMW for mine. I've been very happy with it. The best part is that it doesn't have the seams between panels of aftermarket plates (except bumper to skid)
One thing to keep in mind is broke bolts are not going to be avoidable with more skid plates. I've bent 4 bolts and broke 3 but many of the obstacles would have been major hang ups without a flat belly.
IMG 20170809 201252027
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
got mine from trail armor. I think they were around $700. Should have come with stainless bolts for that price. All the bolts are rusting.
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,656
Oshkosh, Wi
Stainless bolts are probably not a good idea. They are more likely than regular steel bolts and harder to drill out if they break off. A coated grade 5 bolt would be more than adequate.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
maybe. I have not been happy with the bolts that came with mine.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Y'all killing me with the "aluminum not sliding across rocks" again. @SundayRdr hopefully we can find some big rocks to play on Saturday. You can see for yourself.
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Man I just fixed my chit m you already wanting me to tear it up again. Lol. May take 3 yrs for me to fix it again. :D
Reactions: Delton
Tramguage1
Tramguage1
Texan
7,182
27,660
Somereset, Texas
I have a set of 700-4 factory skids. If anyone needs them for a pattern or replacements hit me up. If you pay shipping there yours.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Mine looks rough but i can't blame it considering what it's been through. It's job is to take the abuse. I like that it's only 3/16" thick and I've yet to hear of one splitting unlike the uhmw.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I hope the 700 has better factory skids than the 1000. It comes with a skimpy bikini lol
popeye
popeye
3,273
14,642
kapowsin, Wa
Has any one thought of using a counter sunk torques or Allen head screw on a homemade skid, if the heads weren't exposed, they wouldn't be getting cought and broken off. I know it wouldn't work for the Honda skids and probably the aftermarket ones either.
Sent from my XT1565 using Tapatalk
Reactions: Delton
Neohio
Neohio
Beast of the East
13,475
66,490
Painesville Ohio
The problem I see with that, is you will need to go to a large thread so you get a decent enough sized head to hold it all together.
Reactions: Delton
popeye
popeye
3,273
14,642
kapowsin, Wa
Or just use more screws, and nutzert the frame, I used 3/8" dia screws on the skid of my old tube chassis rock crawler.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
These came with my skids and work great. Haven't seen any bolt head damage at all. Might be able to find them separately somewhere.
IMG 20170818 084505290 1336x752
IMG 20170818 084457967 1336x752
