P1000 Bigtee's Build
Bigtee submitted a new Garage Item:
Bigtee's Build
Been trying to decide on whether to start my build thread or not and decided to go ahead. I want to thank everyone for the valuable information and ideas shared. It's a 2016 1000-5 Deluxe and will mainly be used on the farm for work and hunting, and also, as I have already found out, to run the grandkids around on the farm.
Not many pictures from I first got it, it went off the trailer and straight to the farm.
View attachment 53239 View attachment 53240
Read more about this showcase item here...
Bigtee
Bigtee
556
1,213
Grayson, KY
Got a little more accomplished today. Got the front bar light installed, thanks @GlockMeister for help with the mounts for it.
Bar Light
Also got the switch panel installed, still have a bunch of wire to run. The last switch I need is on its way.
Swicth Panel 1
Bigtee
Bigtee
556
1,213
Grayson, KY
I also got my other gun holder mounted but it was getting late and I couldn't get good pics of it, I'll get some later.
Bigtee
Bigtee
556
1,213
Grayson, KY
Here's a picture of the second gun holder. I keep the shotgun in it all the time so I can carry it here when I take out the big double gun holder.
Gun Rack
Bigtee
Bigtee
556
1,213
Grayson, KY
I also finished up the wiring for now, still haven't got my fan or heat shield installed.
Swicth Panel 3
I cleaned it up good this evening so I can start installing the mudbusters next.
Bigtee
Bigtee
556
1,213
Grayson, KY
That's true, I might just wait and make that a spring project. Hopefully I'll have a winch and mount to install by then also.
Reactions: pct
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Looking good, nice work!
Bigtee
Bigtee
556
1,213
Grayson, KY
Time to start planning for a winch, let me know what you think about this setup.
Superwinch 1145230 Terra 45 4500lbs/2046kg single line pull with hawse, handlebar mnt toggle, handheld remote, and synthetic rope
https://www.amazon.com/dp/B003COQAKA/_encoding=UTF8?tag=sxsweb24-20
KFI Products 101285 Winch Mount For Honda Pioneer 1000
https://www.amazon.com/dp/B018NQ47Z6/_encoding=UTF8?tag=sxsweb24-20
KFI Products ATV-SB Snatch Block
https://www.amazon.com/dp/B0027URE9G/_encoding=UTF8?tag=sxsweb24-20
KFI Products ATV-SCHS Winch Cable Hook Stopper
https://www.amazon.com/dp/B00WMQPP4G/_encoding=UTF8?tag=sxsweb24-20
V-SERIES SEALED WINCH IN/OUT ROCKER SWITCH
Reactions: Bowhunter
Bigtee
Bigtee
556
1,213
Grayson, KY
One other thing it doesn't say anything about the solenoid coming with the winch, what kind do you recommend?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Looks like a good setup! The only thing I would add is a winch on/off to prevent accidentally engaging the winch
Bigtee
Bigtee
556
1,213
Grayson, KY
Good advise, I'll include a on/off switch.
pct
pct
Lost in the hills
790
1,023
Letart WV
Looking good you might checkout super atv winches I have had several over the years no problems use the rzr discount
Bigtee
Bigtee
556
1,213
Grayson, KY
Picked up my winch today, went to Rural King and they had the Superwinch Terra 45 there. I had a gift card to use so I picked it up. Got the KFI mount ordered from Amazon and ordered a power and in/out switch from OTRATTW.
E
elkguide
3,377
7,964
Vermont
Well now that you have a winch.......... get out there and really ride!!!!!
Bigtee
Bigtee
556
1,213
Grayson, KY
Well you all have done it again, I need to stay away from this forum. Ordered the StrongMade front bumper this morning, I really like having the winch mounted up high. I also have an idea on the fix for the side view of the bumper from @Delton pictures in his build.
Similar threads
