![eidnar2000](/data/avatars/m/46/46717.jpg?1682958667)
Hello Board!
I could use some help with an electrical question.
I have a Cole Hersee relay that I can get power to from using the "HondaSXS key on" adapter.
I have tested the key -on power and it's got power to the relay..
I can't get power thru the relay to positive bus or fuse box for some reason. I don't know if I wired something wrong or if the part is defective. I'm just not smart enough to figure it out.
I tested all the accessories and they work of the battery, so it seems the problem is isolated to the relay. Any advice is welcome. Thank you.
I can add additional pictures.
