HolySmit
HolySmit
15
40
Iowa
Anybody have any experience with the DTK hardcab system on a 1000-5? I’m trying to decide whether to go with the full DTK (Moose) Hardcab, or buy the Honda hard doors and rear panel to go with the poly windshield and roof that came with the SE. I‘m not a fan of the poly split windshield or roof that came with it. The windshield feels cheep and it takes two people to get it open/closed. Plus, it does not seal up to the roof, which boggles my mind…
so, the question is, spend $4000 on the Honda doors + rear panel, or spend $4300 on a full Hard Cab (Moose) system.
Thanks for sharing your experiences
8D1D0B72 06D2 442C 9AB3 1E08973BDC5A
X50
X50
59
192
WV
I've got an SE as well and added the Honda hard doors and mid panel. I'm very happy with the results and the install was pretty painless. The only real install issue was getting the clamps on the hard mid panel to close; once I found a suggestion on here to remove the roof first, it was easy. (I opened all of the roof clamps, but left it in place. This allowed me to push it up, out of the way.)
Finding the doors may be a challenge as I was told they are backordered into February. I found a dealer four hours away that had them in stock and ordered other parts from them that would be expensive to freight (hard mid panel and drop in bed liner).
Reactions: Lady01 and BWAF
HolySmit
HolySmit
15
40
Iowa
Hey X50 thanks for the reply, I really like the look of the Honda doors and took down windows. Do you find that your windshield doesn’t seal up with your roof? There is about a 1/2 gap on mine.
X50
X50
59
192
WV
The windshield "mostly" seals up. There's a few spots, especially the two raised areas towards the middle of the roof, that have some gap. Adding some foam to seal those areas is on my to do list. It shouldn't be too hard to get a pretty good seal there as you can slightly lift the roof, add some foam, and then seal it all together when you clamp down the roof.
Reactions: Lady01
slowdryrider
slowdryrider
563
756
Canada
Yup roof doesn't seal up that good. Once I had everthing in place I did run a small bead of silicone along the rubber edge and the roof also into the gaps . It's easy enough to remove if needed. You'll find lots of other air leaks that allow cold air in. Shifters, heahdlight switch , MT/AT switch , steering column .Even the seam in the panels between the floor and dash have air blowing through. All these areas letting in cold air overcome the heater. Any cab you buy is still going to let air in unless you find and seal up every spot that you can think of. So be prepared to do lots of sealing of air leaks if you want any heat.
Reactions: Lady01
HolySmit
HolySmit
15
40
Iowa
Sounds like I better grab some speed tape from the plane hanger and go to work.
Reactions: Lady01
HolySmit
HolySmit
15
40
Iowa
X50, Et al,
Did your factory hard doors seal up good on top against the roll cage? I pulled the trigger on the Honda doors but I’m concerned about how they’ll seal up after looking at how far the roof overlaps the roll cage (See picture above)
Reactions: Lady01
X50
X50
59
192
WV
My doors seal up pretty well. There's a lot of adjustment available between the door hinges and the striker plate.
dezs1775
dezs1775
67
133
Orange city Florida
Not very impressed with the Honda windshield on my SE. It is literally falling apart and the screw locks do not hold it open. Now I have lost parts on the trail. Screws and weather stripping. I wonder if that would be warranty because it’s factory installed?
Reactions: Lady01
bumperm
bumperm
1,851
6,656
Gardnerville, NV
I think the windshield is shipped along with the vehicle and is installed by the dealer. I had to tweak mine a bit, removing a inch or so of the clip on side weather strip where they tried to make it conform to the horizontal bend in at the bottom of the upper polycarbonate panel. Also had to readjust all the roll bar upper mounts. As to the adjusting arms, I've had no problems and no lost parts. They may consider that a user thing though, if they are not adequately tightened (not saying yours weren't), like most fasteners on parts subjected to vibration, they'll come loose. From all reports here, SuperATV's windshield is better. Judging from their back windshield, that I added, it's better made - though I wish they'd of designed it to open a bit higher, at least so the opening part is horizontal.
HolySmit
HolySmit
15
40
Iowa
Dezs1775- I totally agree, this windshield isn’t great. I also had to trim odd about an inch of the weather stripping on each side to get it to close, and its disappointing how big the gap is between the windshield and the roof. Maybe the guys at Moon Motorsports in Monticello, MN didn’t install it quite right, or it’s just not a good design, either way I think a glass windshield is in my future.
Reactions: Lady01
bumperm
bumperm
1,851
6,656
Gardnerville, NV
My windshield fit to roof is actually quite good, but it didn't come from the dealer like that. After I got it, I loosened all the clamps, straightened everything, then tightened it all back up.
HolySmit
HolySmit
15
40
Iowa
I decided to go with the Honda doors and mid panel, and I am quite pleased on how the doors fit and how they feel. These things are heavy and they seem very well engineered. The mid panel was a little bit of a challenge to fit into place, and once installed I did have to shave about a half inch off of the plastic lip of the front of the dump box top lip to clear the mid panel when tipping it up. I also found that to get the doors and mid panel on and in place I needed to detach the roof and windshield.
My one complaint about the doors is that The nylon stop strap only allows them to open to about 45 Degrees. If this strap was just a 1/2 longer I think it would be perfect. I do really like the look of the doors once I put my side panels on.
I took it for the first test drive down the road at speeds up to 55mph, it’s about 20 degrees outside today. Here are some thoughts and observations-
1. Pretty noisy in the cab, maybe I could add some sound dampening material to the roof?
2. Cold air absolutely gushing in from both shifter levers and the foot pedals. I need to find a way to seal these up.
3. Buying the seatbelt bypass connector immediately. I can’t stand that safety feature any longer
EB9C5C54 E951 495D 8AF3 FF1FEFD64CD0 EE6CE320 C8F4 4128 858C 24C929AE3733 97619E94 AC71 44DA 844B 06AD3F7F09A4 2CBB9869 1B11 493C 8B35 0BD307D6D102 B132EE1E 9A62 454C 876B F3AA6377F593 2F553D9B 327D 423B B290 81BD368C796D 0863EA93 6D64 462A A5CB 42611E854A1A F7DEE4B7 26D1 41E6 A988 0B3BAC88F609 F5BB143C FBD2 4925 A61E 998E719D4CF1 D1AA5C4C F455 4835 8C9A CBD6C26DFB52 0EA864FD 6EBB 4574 BA13 BA406FC2BD40 E5E8AA53 8AC1 4CDB BB5C 8D4DB49D76DA 2695B3F9 F774 4DD2 8305 8DDEA2F9EBCF 7B5A2681 5F2E 4440 9E14 90FA5E6DA10C 2058B0B9 8941 4B24 9917 904F885DD3CB 9B7A8F44 2AA1 447A A71C 180C86DE4C51 FF12B8FD 937F 4DFA B76F F051D0B8877F 6000DE42 28BB 4426 955F 63DAC71E84F1 8CD86B52 D183 44D2 8CA6 BC58D1B3AE5C A94B5B67 04AF 4725 AC92 BA557D2A0759
Surveyor
75
240
Auburn, MI
Interesting to see that the interior color of the doors and midpanel are gray. Mine are black. Purchased about 2 years ago.
Reactions: Lady01
HolySmit
HolySmit
15
40
Iowa
I wasn't impressed with the hard Honda cab at all. Doors are great but there's ALOT of places Honda could of addressed leaving air in. I tried to communicate with Honda with mo luck.
I couldn’t agree more. Once I got the cab on and took it down the road I was super disappointed at the enormous volume of air coming in through the shifters, steering wheel boot, and foot pedals. I’m researching ideas on how to seal these up but not finding many answers. The cold coming in is one thing, but I’m more concerned about the dust! I hope I didn’t screw up by not buying the CanAm Defender limited Or Polaris Ranger Northstar Edition!
If anyone has found a solution to this please let me know.
