Intro & 4" portal - wheel offset question
Z
ZPIONEER10005
15
83
North AL
This is my intro.
I have recentlry purchased a 2018 Pioneer 1000-5 LE
When purchased, it already had 4" 15% SATV portals |14"x 7" SB-4 bronze wheels with 4+3 offset | TTC 0" front and rear A arms.
I am wanting to try 15" wheels with either 5+2 offset or 6+1 offset. From everythign I have read on portals and reccomendations I know this is not reccommended. I would prefer to go to 6+1 but I am currently measuring 1 1/2" from the back of the wheel to the portal mounting plate. This being said that woudl leave me with the 5+2 offset, leaving 1/2" between the wheel and the portal mounting plate.
My question is, has anyone experimented with 5+2 or 6+1 offset wheels with 4" portals to see if they will work?
Z
ZPIONEER10005
15
83
North AL
The "Machine"
20240225 160258
108,218
Currenlty the Machine is running 32 x 10 x 14 pro armor crawlers.
I will be using the machine for hunting. Duck hunting flooded rice fields as well as general hunting and work.
Dont forget to hit the “reply” when responding so that person gets a notice like u did😉 little forum help/advise
How deep are your fields? Reason I ask is that people that get portals are either liking the GDog look or they swamp bog. Portaols tend to give problems in the long and short runs. So trying to justify if u truly need them of not? If you will be ass and elbows deep in them fields then I can see it. I hunt in some swamps but not to cover the floorboards, water intrusion at times yes, arched arms, my 30’s and some preload on the shocks is enough. I have a 0 offset tire same size all the way around and I use @RB3offroad wide track bundle for spacers that correct the track of the rig. Buy once cry once and work smarter not harder also.
Who makes your portals and arms help in your questions as well cuz they all are not created equal. Another reason we like pics😉
Z
ZPIONEER10005
15
83
North AL
Looks good the way it is!
Not very big portals to me. At least from the pic. Looks like u can achieve that with preload and maybe a little taller tire.
This is mine. Its a 16
Good looking machine Remington.
Some of the spots we get to have 30" + of water
I like that my machine has a 15% gear reduction with the portals. They are 4" by SATV.
I do not like how wide they make the machine.
Z
ZPIONEER10005
15
83
North AL
Also my machine has a decent bit of preload on it currently. I am waiting on my spanner wrenches to arrive and then i will be reducing the preload to bring the overall height of the machine down as much as I can.
SuperATV
SuperATV
1,254
8,771
Madison, IN
www.superatv.com
You're cutting it awful close with a 6-1 offset. Even with 15" wheels. I'm betting you can get away with it, but you won't have any room to spare...and you'll really need to watch where your brake lines are ran. Make sure they are out of the way. Test full turn and full drop and compression after adding the wheels.
Mudwisel
Mudwisel
7,109
62,451
Tampa Bay Florida
This is my intro.
I know people using 5+2 on 14 inch rimes. They are the single idler version.
Z
ZPIONEER10005
15
83
North AL
Well I have decided to go forward with a set of 15x7 / 6+1 wheels to see how it works. I found others running 4" portals with 6+1 offset on razrs as well as 1 individual on facebook with a Pioneer 1000.
Once installed I will post pics
