![pit](/data/avatars/m/10/10567.jpg?1522158404)
1. I'm going with the under the hood option and I've seen the main two choices on here are the Odyssey PC925 and the Mighty Max 26-12. $187 vs $55 seems like a no brainer, but which did you choose and why?
2. I had the winch installed by the dealer at purchase time, so I'm not real sure on the wiring. I studied the installation instructions from the Honda accessory website and it appears to me (see attached pic):
-the black cables with yellow and blue tape coming out of the bottom of the contactor are the power cables going to winch
-the black cable with the blue tape coming out the right side of the contactor is the winch sub harness
-the larger black cable coming out of the left side of the contactor is the winch battery cable that runs to the starter relay and then the red cable runs back to the stock battery.
So if this is all correct, is the only cable I have to change is the red cable from the starter relay to stock battery so that it goes from starter relay to 2nd battery? I'm sure this is a simple question, but I'd rather be safe than sorry and not break something that is working perfectly fine right now!
