P1000m3 My 1000 Build!
Jdiehl7
83
103
Houston
New to the forum here! Just bought myself a 2018 P1K EPS, now i'm starting to put it together! Being 21 and still in college, while running my company, I don't have much time to work on it, but I will be using it every weekend deer hunting! Here she is when I picked her up from Great River Honda in Mississippi!
IMG 2647
First Step was to get the Super atv windshield on, then on to mount my bumpers. Ordered the wild boars because they had matching front and rear, as well as protected the winch! Both front and back came with flush mount cubes as well! I built a top for it temporarily (for a year or so)out of 1/2" treated plywood, conduit straps, and spray can bedliner. Cut the front to match the curve of the bar, diagonal cuts on the edges t match the rollcage, then bolted her down!
IMG 2675
Next was to add a curved lightbar for driving around our place late at night as pigs/coyotes/bobcats/raccoons all go nocturnal after the first couple weeks of season. I originally purchased the 50" auxbeam rgb bar, but the green color sucked, and the lightbar didn't effectively shine past 75 yards or so. Returned it to amazon today and purchased a plashlights 50" spot beam white curved bar that puts out 31,500 lumens!! Should do more than enough at long range with the added help of my the flush mount cubes! Also put on an infrared lightbar n the top tube of the bumper with pipe mounts from tractor supply! Threw in a 5000lb winch from Harbor Freight because of the good reviews, and because it was on sale! Currently I am working on the electrical... We ran it at the lease this past week, me my dad and uncle all stayed dry with the windshield and roof. Had an overheating problem, and boiled the coolant, so i burped the system and ran it hard sunday and temp didnt get above two bars. It will go to the dealer if it happens again! Now I am getting ready to do the first service on it!! I added in the 14 slot rocker switch panel, and I am now awaiting my wire loom, blue sea fuse block, stinger switched solenoid for master power, odyssey battery and the dual battery kit, all matching custom rocker switches, dual voltmeter that matches rockers for batteries, dual usb port for my nightvision scope to stay plugged in that also matches the rockers, and 8" radiator fan for bilge area to get the heat out.
IMG 2687
My To-Do List:
14" MSA Core 20s with 28x10x14 efx motomtc tires
Bluetooth/aux chord sound bar
Road Feeder
Interior dome light
Add Insulation under and behind seat to alleviate heat issues
Custom metal roof with rack
Custom high rack to match roof
Receiver hitch at the top of the roof for a smaller winch to help assist loading animals into the buggy by myself
A set of cubes to throw light to the caddy corners on long curved roads to look ahead for pigs at night!
My overall goal is to keep the machine looking very clean, no wires blatantly showing, all switches feeding accessories with corresponding names, all wiring in braided wire loom with heat shrink on the end to help keep things clean, yet be completely functional for hunting and working. I already love this machine, rides great, and has tons of power! Moved a heavy built deer stand across our 1600 acres through washouts and extremely soupy clay and never skipped a beat! And I even got my first kill out of it! I think im gunna name it the PKR(pig killing rig)! Thanks for tagging along, I'm addicted for sure! IMG 2698 IMG 2691
Neohio
Neohio
Beast of the East
13,478
66,530
Painesville Ohio
Welcome to the club from Cleveland, Looks like you are off to a pretty good start one week into ownership!
Reactions: TimG and BWAF
Todd627
Todd627
56,616
617,890
MI
Welcome from the Great Lakes State :) That is one wicked PKR my friend!!!
Koda
Koda
565
2,309
Canton Ga
Welcome from North Georgia. Nice
TimG
TimG
OLD SKOOL
774
3,814
Southern Indiana
Lookin good ! FYI on our group ride in Utah only one Pioneer 1000 had overheating issues. It had a front bumper like yours. Not enough air flow ?
Reactions: BWAF
Jdiehl7
83
103
Houston
I was running less than 10 miles an hour moving a Deer stand in deep wet clay, burped the coolant then ran it hard the rest of the weekend it stayed at 2 bars, if it does it again it’s going to the dealer after I test it without the bumper!
Reactions: BWAF and TimG
TimG
TimG
OLD SKOOL
774
3,814
Southern Indiana
I honestly don't know what Curt the guy with the overheating issues found out. We were climbing mountains at up to 12,500 feet. Hope she stays cool on you. Let us know if you find anything out.
Reactions: Isaiah and BWAF
Jdiehl7
83
103
Houston
While I was letting it cool I was messing with the wires, the fan hardly ran before it overheated, then when it was sitting there after messing with the wires it came on more idling in 20 minutes than it had all weekend
TimG
TimG
OLD SKOOL
774
3,814
Southern Indiana
You may be onto something there.
you may be onto something there.
320,750
You’re kicking some serious butt on that guy in a short time nice job!
Jdiehl7
83
103
Houston
or possibly a temperature switch not kicking the fan on soon enough and shutting off too soon ?
It turns on for a short time every minute or so, could be a faulty temp switch, or the control module isn’t set right. You’d think the fan would run for a longer duration than 15-20 seconds. May add a jumper switch if it acts up and I take it in, won’t cut the oem fan harness until dealer says he can’t find anything if it keeps acting up. How often and how long does your fan run when your machine operates at high temp?
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Welcome to the forum. Sounds like you're off to a great start cause machine is looking good!!
Reactions: Jdiehl7 and BWAF
Jdiehl7
83
103
Houston
My neighbor told me he has some 18 wheeler mud flaps as well, going to try to fab up some fender wells to keep all that red clay out of there on wet weekend trips to the lease!! May have to order a sheet of that thin 1/8” heatable plastic and bend it to the shape i need, but will try the truck flaps first to see if I can’t get it covered up!!
Reactions: BWAF
