P
Spent the last few days installing the cab heater in my new 22 P1K5 Trail, a vary tedious install. Along with the cab heater I also had to purchase the Honda Fuse Box, Fuse Box Wiring Kit and Fuse Box Bracket.
Upon completion I started up the buggy and got it hot to circulate the coolant and to top it off. I then wired the New Fuse Box to a secondary battery, temporarily, until I get my battery isolator from the club store. Figured I would just need power to check out the heater fan and controls. I found the “trigger” connector under the “blue” tape just aft of the stock battery. I connected the trigger wire to the new fuse box onto the “trigger” connection, Plugged in the power lead from the heater to “aux 1” on the fuse box, when I turned on the ignition key and then turned on the heater blower nothing happened!👎 I changed the heater power lead to several other connections on the fuse box and Nothing!👎👎 So for troubleshooting I checked all 8 10 amp fuses in the new fuse box, all okay. Next I checked all the fuses in the buggy electrical fuse box, those were all okay.
Then I decide to build a simple power lead to power the heater from my secondary battery, it Worked the blower was running and air was coming out of the vents/demister. Continued so I get the pictures correct.
![48110902 6ABE 47F4 9043 F9F34020FDBE 48110902 6ABE 47F4 9043 F9F34020FDBE](https://hondasxs.com/data/attachments/356/356627-0d56ee66c5b24fdc290cd637422383dd.jpg)
