P500 P500 compression
Crochetchance
New Iberia, La 70563
My p500 is smoking really bad I ran a compression test today and the gauge showed 125 on dry test and 130 on wet test is this good r should I be concerned I do not know what the compression should be and I don’t know anything about the bike as I picked it up used 2 weeks ago
906UP
906UP
13,205
123,458
da Yoop
I don't have the spec in front of me but can look in the shop manual tomorrow, that doesn't seem to be too far out of the normal range. Did you have the throttle wide open while you were cranking it for the comp test? That can make a big difference in the readings also.
More questions......
When is it smoking? At idle, on start up after sitting a while, under throttle, on deceleration? All can point to different issues.
What's the history of the machine? Miles/hours?
Has it ever been swamped, ingested water/mud?
What kind of oil are you using and has it been changed regularly? (it's not uncommon for synthetics to burn off a little)
For what it's worth, my '16 P5 had around 2500 miles of absolute hell......WFO just about everywhere, swamped several times and just beat to death in general. It would puff a little at start up after sitting a few days which points to bad valve seals and would've continued to run like that for many years. I only replaced them because I pulled the top end to do a big bore kit, the original cyl & piston still looked new. These engines can take a ton of abuse if properly maintained. It's now at about 4000 miles.
Compression means nothing concerning smoking. I've seen several machines have great Compression and run like a top all while smoking like trains.
The oil rings keep oil out of the chamber, the top rings build Compression.
906UP
906UP
13,205
123,458
da Yoop
That's what I was getting at with my questions but a new member and this is the only post.......we'll see if he shows up again 🤷‍♂️
Crochetchance
This is what it’s doing and I don’t know the history of it I just got it and trying to get it going thanks for the responses
Crochetchance
No I didn’t have the throttle wide open on either test. It smokes a little at start up but smokes a lot when accelerating. It runs really well
NTCPrezJB
NTCPrezJB
President of #NTC
101,970
910,939
Canton, OH
I suspect you tried to post a video. You have to put it up on YouTube or similar first and then post the link here.
906UP
906UP
13,205
123,458
da Yoop
Piston
I'd suggest looking into a new set of piston rings at minimum, sounds like the oil rings have failed.
2015 Honda PIONEER 500 - SXS500M OEM Parts | MotoSport
