P500 p500 cuts out at 40 mph
Duckhunt
Welcome to the big show!!!
Absolutely. What you're hearing is the rev limiter, I believe is at 6800 rpm.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I don't no it could go 40 .
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I hear some are equipped with 906UP Gears:cool:
FC3461CD B052 4A76 B76A 1A967D69C485
906UP
906UP
13,205
123,449
da Yoop
thax for the feed back !! Vinnie
Hey @vinnie55 , through my testing I found there is a higher rev limit in the lower gears 1(L) thru 4th than there is in 5th, this was Mother-Honda's way of limiting the top speed on a short, narrow machine. It doesn't hurt the machine a bit to run it against the limiter in 5th. If you want it to go a little faster & bring the RPMs down at trail speeds we found a way to do it, click the link below. It involves tearing the rear cover off the engine to change 2 gears in the transmission.
