P1000 Rear Bumper options
Moxdmguy
60
402
53
Lone Jack, MO
Check out Texas Tough Customs. They have a rear bumper thats frame mount and you can put a winch on it if you want to. I have one of their front winch bumpers and it is super heavy duty. TTC Rear Winch Bumper (Bare Metal) | Texas Tough Customs
I’ve been very happy with this bumper. Was a bit of a challenge getting everything to line up for the install but is solid as a rock
IMG 9449
someguy1313
someguy1313
174
383
SouthEast
Had the EMP. generally liked it for what it was. on post 5 and 6 here there are two SATV bumpers mentioned.
and this
any thoughts comparing between the two are appreciated.
want a reasonably durable bumper but if i'm pulling out of a hole, i'll be running off the receiver.
TIA
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,657
Oshkosh, Wi
I have the tuber bumper. It works well with my rear winch and HMF muffler. It does stick out to the full width of the roll cage and I have bent one side backing into stuff
I do like it as a strap storage spot. I only use the hitch for recovery
1000003450 1000003451
someguy1313
someguy1313
174
383
SouthEast
nice. thank you. looks like an easy install?
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,657
Oshkosh, Wi
good to know... can you advice the circumstance of the failure?
The nuts are welded into the end of the frame on 2 sides and likely are intended to be removed several times. The bolt was tight coming out likely from corrosion and the weld broke. I fished it out with a magnet and then drilled and oversized hole for a flange nut and welded the new nut in. Not perfect but not accessible another way
Reactions: someguy1313
someguy1313
someguy1313
174
383
SouthEast
@ToddACimer
bumper failures suck.
thanks for the insight!
