P1000 Replacing clutch pack on the Beast
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Before I can fix it I've got to remove the ice build up!
IMG 6227IMG 6228IMG 6226
& remove skid plate to change oil!
IMG 6225
Eltobgi
Eltobgi
4,599
15,186
North Dakota
While the machine is warm time to pull the plastics...
IMG 6235
Removed the seat back
IMG 6236 IMG 6237
And after an hour of cleaning dirt and ice from screw and push rivets you get a good look at it!
IMG 6241
popeye
popeye
3,273
14,642
kapowsin, Wa
When did they go out?
Reactions: AKRider
ghost
ghost
993
1,873
BC
Yeah - good to see it all "documented".
I like that bumble bee color on the P5
Reactions: sharp
popeye
popeye
3,273
14,642
kapowsin, Wa
They start slipping December 26th! Drove it home and parked it and didn't move it until today to get it ready to replace!
Bigger tires? How many miles? Any thing that you could pin point it to when or why it went out?
Reactions: pct and AKRider
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Highlifter lift, 72" snowplow...
Well It happened while the snow plow was attached! I will admit that I got it stuck and shifted from reverse to drive over and over again until I was able to get out! I was thinking at that time that it might harm the clutches but was determined to get out. About 5 miles down the road began plowing a neighbors crossing...it was doing fine no issues...stopped for oncoming traffic...and pressed the pedal and nothing! I didn't expect to loose a clutch pack this way! Seemed to happen all of a sudden! But still can't say it was actually from plowing!:(
AKRider
AKRider
1,402
3,224
Palmer, Alaska
I can't tell because of the lighting, but does the oil have a red tint to it?
Reactions: pct and Eltobgi
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Installed new filters ready to remove clutch pack after cleaning! Going to have to hold off until tomorrow still a lot of ice and dirt everywhere! I'll clean it up tomorrow and continue!
Here are some pics of the clutch prior to soaking in oil...
IMG 6253 IMG 6255 IMG 6256 IMG 6257
Eltobgi
Eltobgi
4,599
15,186
North Dakota
It was definitely discolored maybe it was just the light or lack of good light! I've only ever used Honda Oil! You could see the color a little when I was draining it, again DCT was noticibly darker
AKRider
AKRider
1,402
3,224
Palmer, Alaska
It sure is.
Reactions: pct and sharp
popeye
popeye
3,273
14,642
kapowsin, Wa
How much did all of this cost ya?
Reactions: CumminsPusher
