P1000 Rocker panel
K
kyrider1000
67
217
Kentucky
Looking for a 6 gang rocker panel to put in place of my Warning label on my 1000 3 seater . Something that wont break the bank and yet look good . Also one that is a easy install .
Any thoughts / ideas ?
JenElio
JenElio
65,894
614,367
Loxahatchee, florida
Lots of them!!!
Use the search bar up top, lots of different vendors/suppliers for those.
Couple site vendors as well but can't remember their names right now.
I have a PBR plate, it's been good. They have a lot of configurations too.
Reactions: Rayger143
13,477
66,519
I know you said without breaking the bank......
Try to stay away from "carling style" switches made in China. Buy legit Carling switches from a reputable source. But they are not cheap. A bunch of us went with china switches initially. and they like to fail at the worst times.
Most of us have went with the following switch setup
The price isn't horrible when you factor in $20ea for legit Carling switches. This option greatly simplifies wiring as well.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,496
15,042
what he said lol. I'm still running the garbage China switches. I replace at least one a ride. I don't recommend trying it.
K
kyrider1000
67
217
Kentucky
So where did you mount your panel at ? Any pics ?
DRZRon1
DRZRon1
896
2,918
Just search jeep jk or similar stuff - cheaper than sxs stuff
E6266198 7CD0 4A49 B836 12F5FD468119
13,477
66,519
In the warning label area. I didn't even remove the sticker. Added the 8 gang switch, 2 usb ports, a radio controller. And a on-off-on toggle switch that remotely feeds the 8 gang panel either key ignition or 2nd battery.
Rayger143
Rayger143
2,767
23,996
Winfield, BC Canada
I had one from PBR products. I am now using one from Crossroads 3D. I ordered my switches from the club store.
IMG 7360
Reactions: JenElio and Homer
bumperm
bumperm
1,852
6,659
Gardnerville, NV
You could also go the DIY route for cheap (but more work), to get rid of the "You're All Gonna Die" warning panel. Advantage is doing the layout exactly how you want. Textured ABS sheet plastic is available that pretty much matches perfectly. Warning, when using this approach, you quickly find out that Honda didn't make hardly anything parallel or at right angles to anything else!
20210826 203158
20210826 210127
20211221 215040
