![Robobrainiac](/data/avatars/m/25/25561.jpg?1599011255)
Robobrainiac
If you have an auxillary battery and use the True Am Isolator you should be able to bypass the isolator to self jump start your rig. This method worked for me so I made a handy dandy little tool to keep with me in the machine.
Purchase This
Purchase Two Of These
Then Open The Box When It Arrives In The Mail
Place The Product On Your Fiero Workbench Of Your Choice And Grab A 10mm Socket And Wrench
![IMG 1101 IMG 1101](https://hondasxs.com/data/attachments/415/415198-99ee508cb50f27bbcdf3770849150704.jpg)
Remove Both Nuts From The Clamps
![IMG 1104 IMG 1104](https://hondasxs.com/data/attachments/415/415201-9f8ddeba5bcaf640579d824501582e3e.jpg)
Place The Cable End Over The Threaded Stud
![IMG 1105 IMG 1105](https://hondasxs.com/data/attachments/415/415202-2487ac11fd0f9ccfe31d5996496289d7.jpg)
I Used A Stainless Washer To Help Secure The Cable End
![IMG 1106 IMG 1106](https://hondasxs.com/data/attachments/415/415203-39c74c7bbe2f1bf13990d29009b15fa6.jpg)
Put The Nut Over The Washer
![IMG 1107 IMG 1107](https://hondasxs.com/data/attachments/415/415204-718b15d62e855e982b12f5440b71ee1f.jpg)
Then Tighten It Down
![IMG 1108 IMG 1108](https://hondasxs.com/data/attachments/415/415205-d2348f0a2295513b7022806ea78e5799.jpg)
Repeat That Process For Both Clamp Ends
![IMG 1109 IMG 1109](https://hondasxs.com/data/attachments/415/415206-dd7fff75d6f9064e96b5079fbea25a6a.jpg)
Finally You Should Have Something Like This
![IMG 1110 IMG 1110](https://hondasxs.com/data/attachments/415/415207-fdcd30665806c59fa0210cd9b208e094.jpg)
Use the jumper to bypass the isolator to help start your machine when your main battery is low/dead. Your auxiliary battery needs to be in good condition for this method to work. Place one clamp on your main battery positive post and place the other clamp on your auxillary battery main post or on the side of your isolator that the auxiliary battery attaches to.
Purchase This
![IMG 1099 IMG 1099](https://hondasxs.com/data/attachments/415/415196-31068c597f425d91a0e22fdfb1fbfec1.jpg)
![IMG 1100 IMG 1100](https://hondasxs.com/data/attachments/415/415197-5194b0ef0b15d1b91c47be558faaf29c.jpg)
![IMG 1102 IMG 1102](https://hondasxs.com/data/attachments/415/415199-09e68b8a1d78b72a30d4c7c201199a50.jpg)
![IMG 1103 IMG 1103](https://hondasxs.com/data/attachments/415/415200-37b3237738c1f97f94ff61ac8b988de5.jpg)
