P1000 Steep Slopes and hills
320,750
Likely bad advice and borderline condescending. Gotta defer to the other guys on this one.
Didn’t mean anything condescending. One foot on the brake, start giving gas and release brake. No different then a car.
TxDoc
TxDoc
1,677
5,812
TEXAS 🇨🇱
photos.app.goo.gl
New rider here- P10006- Question about going up hills, here's the scenario:
Going up a steep hill. STOP on hill for random reason, but then I want to keep going up the hill. Unfortunately I am rolling backwards. How can I continue going forward without frying gears, transmissions, etc?
Do I just ease into the gas as I'm rolling backward?
2023 1000-6 Models WITH HSA
The 2023 Honda Pioneer 1000-6 Crew has a Hill Start Assist (HSA) switch on the SXS1000M3D Trail/M3D Forest/M5D Trail/M5D Forest models
Sent from my motorola edge plus 2023 using Tapatalk
ChadD
ChadD
23,360
233,968
Brown City
2024 Honda Pioneer 1000-6 has a Hill Start Assist (HSA) button on the dash that allows the driver to temporarily apply brakeforce while moving their foot from the brake pedal to the accelerator. This helps prevent the vehicle from rolling back after stopping on an ascent
You can say that again 🤔🤣
chadley2301
7
74
Southwest Michigan
  1. 1000 6 Crew
@CP - Right on, much appreciated and ... More importantly, I went out this evening and executed the two foot gas/brake combo to perfection. Great advice. HSA would be nice, but this'll do fine.
On a side note, this machine is incredible. My Polaris buddies are already trying to figure out how they can sell their rigs and get a Pioneer.
NTCPrezJB
NTCPrezJB
President of #NTC
101,970
910,943
Canton, OH
I’ll specifically add get the clutch fully engaged on these P1K’s asap. If the wheels aren’t turning and you are on the gas you are slipping the clutch. As you stated you’re familiar with driving a manual transmission I won’t bother to explain that further. A manual transmission is effectively what you have in this machine though. The clutch engagement is just electronically controlled instead of by a user controlled clutch pedal. I believe the consensus is something around 3 mph is fully engaged. (Tire sizes/gearing changes/etc not factored in)
Ultimately though if the tires don’t move when you apply the throttle/skinny pedal/gas pedal … stop and pull a winch line. Your clutch pack will live longer.
TripleB
TripleB
11,991
102,010
Caryville, Tennessee
Screenshot 20240430 081105 Brave
Screenshot 20240430 081115 Brave
Screenshot 20240430 081206 Brave
Get you one of these and bolt it to your brake pedal for easy 2 footing stopping on steep ass hills.
TripleB
TripleB
11,991
102,010
View attachment 427234View attachment 427235View attachment 427236
Get you one of these and bolt it to your break pedal for easy 2 footing stopping on steep ass hills.
Even better deal. Give one to your friend.
267,237
I'll take who's never driven an manual transmission for $1000 Alex.
Who is the @chadley2301
But as already stated many times, hold position with brake while applying gas then let off brake to go forward.
Bighat
Bighat
876
3,744
Gallipolis Ohio
I would never use the two feet method others mentioned here because someone will say, you drive like a women. When letting off the brake just try to hit the gas faster, like drag racing. Doing this will put you into launch mode. From there you should be able to clear the trees at the top of the hill. If there's trees at the top of the hill. If not you'll here a loud plunk as you roll farther backwards.
108,208
On a side note, this machine is incredible. My FIRE TRAP POO POO buddies are already trying to figure out how they can sell their rigs and get a Pioneer.
fixed it for ya😜
Thats easy for them! Just wait for it……..
