P1000m5 1000-5 Rear Door Inside Storage Modification
czajkaej
czajkaej
Ridgecrest, CA
Honda changed how the panels mount for 2022. I was still able to add storage and all, just had to adapt a bit.
B139050B 516A 4DE6 B3B9 17E0F7004171
27F428F1 9B15 4EC7 9DA9 83C5451083AE
Topguntrigger
Topguntrigger
15
58
Invermere
View attachment 368617View attachment 368618
Good video I am actually going through the same thing right now with my 2022 trail the issue is I don’t like how your panel sticks out from the main door. I would like to get it as tight as factory. I’m looking for a flat nut to go on the exterior currently.
If anyone else has any great ideas to fix this issue, please suggest .
bumperm
bumperm
1,851
6,658
Gardnerville, NV
I agree, that's sub-optimal using a nut and washer on the outside. As you said, has the color panel sticking out too far. The fix I'd use is install rivet nuts in the door panel. Use a washer only on the inside. They sell rivet nuts with a larger outside flange that still has the threads almost flush with the surface. Then proceed as normal (previously discussed) fitting the color panel.
I also recommend either small O-rings on the ball end shaft to seal on the inside surface of the button to keep dirt out of the button mechanism.
Update: after a year of use. The O-rings work well, but require a bit more force to compress each o-ring to get the button to snap into position. I found that washers made of closed cell foam-rubber sheet work even better. I could not find an on-line source for such washers . . . so made them.
Topguntrigger
Topguntrigger
15
58
Invermere
Good idea thank you
Robobrainiac
Robobrainiac
2,475
8,662
Does anyone drill a drain hole in the bottom of the doors after the mod?
Y
Yakman
126
313
WA
It's a little crude but after insulating you could use a large waterproof stuff sack. Put it in the hole then fill with ice and drinks. When you're done you can pull ice and water right out the hole.
Or you could skip the sack and just use the new opening. It has a drain hole at the bottom. I tried it on mine but there was too much engine heat and the ice melted quickly.
108,108
Dude, Dave hasn't been on since 21' I'm not sure if he still has his P1
Sarbuck
Sarbuck
55
186
Anyone who did this push pin rear door storage mod...any regrets or issues over time? I'm going to cut this weekend...wanted to check to see if anyone wishes they wouldn't have done this mod and why. Thanks.
Reactions: JenElio
bumperm
bumperm
1,851
6,658
Gardnerville, NV
I make shims for certain guns, so have electric/hydraulic pin press and all manner of punches I can use to make sealing washers. I've ordered some foam sheet for the washers to go on the ball-end shaft (replacing the O-rings I'm currently using). Problem with the O-rings is adjustment is critical, a bit loose and the dirt can still foul the button release mechanism, too tight and it's difficult to latch. I'll report back when I get the foam washer mod done.
Reactions: Sarbuck
Sarbuck
Sarbuck
55
186
Great. Thanks. I’ll do what you did if it works. No one has replied about regrets doing this mod so I’m on it tomorrow.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
You're gonna like it. Be sure to read back through this thread as there's a lot of helpful info. I used an oscillating multi-tool to thin the back side of the door covers, at least to the point that the nut on the push button would be fully engaged with the button threads (even at the back). This gets the color panel as close to the door as is reasonably possible. I used a hole saw at the corners of my planned cut out (no sharp corners), then cut between the holes for the opening.
Sarbuck
Sarbuck
55
186
Did you loctite all nuts? I see some do, while others say it’s not necessary.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
No need as far as I can see. I've not experienced any coming loose.
BTW, I just replaced the #2 O-rings I was putting on the ball-end shaft to seal dirt out of the buttons. I bought a sheet of 1/8" EPDM foam sheet and punched out 5/8" OD washers. The foam is softer than the O-rings, of course. Ball ends needed to be turned our 1/2 turn but the buttons are easier to operate and should seal even better.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
I made a bunch of foam washers for the ball end catches used for door storage - OD 16mm, ID 5mm and installed them on my sxs. Then did a search to see what similar washers sell for, the thought being to offer them for sale. Then I came upon suitable washers used for mounting the body on RC cars. These should do a better job sealing the push button catches to keep the dirt out of the mechanism. Reasonably priced on Amazon so I won't be offering them for sale.*
Foam Washers
*Note that I have not tried the linked washers, but they should work, though will doubtless require adjusting the length 0f the ball end catch a bit. The ID is 6mm, which will be a bit loose on the shaft (I made mine 5mm). As previously posted, when I removed the rubber O-rings for the foam washers I made, I had to unscrew the ball end by I/2 turn - (Measured this by marking end of ball with felt tip so I could see 1/2 turn).
