2009 Big Red not starting
P
Phil1234
My big is not starting, battery is good, fuel pump turns on, fuses are good, put in a new battery, stated after sitting for several hours, then nothing again. Not even turning over when quits. All dash and headlights come on correctly. Any ideas?
P
Phil1234
The motor is not turning over.
Rotated around the relays located in the fuse box.
64,288
Are you getting power to the starter when key turns to crank?
If yes.
How many volts and amps?
If acceptable.
Pull starter out and see if it runs from a 12v source.
If yes.
Check to insure crankshaft spin manually?
If yes.
Then im stumped!
If no,
something is locking motor up.
P
Phil1234
It appears to be the starter, if I tap the starter prior to starting, it goes, new starter I guess
