![Whistled03](/data/avatars/m/6/6092.jpg?1484650724)
The self leveling rear shocks do work on the 1000-3 if that’s what you’re asking.
I was talking about 1000-5 shocks fitting on the 700-4. I don’t think the 1000 will bolt up to 700
Please being them. I was just reading a thread that the front work but the rears don’t. But I bet I can find out at the takeover. Are they the fox ones off the LE or just the pioneer ones?Oh gotcha, I think I saw someone tried it and it worked. Maybe I’m wrong.
I’ll bring mine just in case you want to try it.
Edit: found some info.
P700 - RB3offroad Shock sleeve kit to adapt the stock Pioneer 1000 shocks to your pioneer 700!
Think all it takes is bushings. Tram installed some on Walters.I was talking about 1000-5 shocks fitting on the 700-4. I don’t think the 1000 will bolt up to 700
I'll be bringing a set of 4 off a P100-5 Deluxe also.I’ve got stock fronts for p1000-5 and adjustable p1000-3 rear shocks. No FOX, just the plain oem but the adjustable mich be cool?
The 1000 front shocks will work on the 700. You will need 4 -1000 front shocks for the 700. The fronts need the RB3 sleeves and the rears will bolt in with no modifications. The 1000 rear shocks have a clearance problem on the 700. Can't remember if it was the sway bar or suspension that was the problem.I was talking about 1000-5 shocks fitting on the 700-4. I don’t think the 1000 will bolt up to 700
So you put 4 fronts on Walters?The 1000 front shocks will work on the 700. You will need 4 -1000 front shocks for the 700. The fronts need the RB3 sleeves and the rears will bolt in with no modifications. The 1000 rear shocks have a clearance problem on the 700. Can't remember if it was the sway bar or suspension that was the problem.
Yes 4 frontsSo you put 4 fronts on Walters?
I will have a set of bushings with me. If we have 4 front shocks we can do the mod in about an hour! It will give you 1 1/2" to 2" lift. If your hauling in a toy hauler, you may not get it back in after the mod.
Yes not site theres any differencesI have two front shocks and two rear shocks from the three seat model. The three seater shocks should fit correct?
If bumper is still available I'll take itI have a few items collecting dust for a Pioneer 1000. Available only for pickup at the Takeover.
I have 5 Roctane XD 28x10x14 on STI HD3 wheels, 50%+ tread. 1 tire hase a cut in sidewall, could run a tube in it for your spare, other 4 in decent shape. $150.00
Strongmade front bumper $100.00
Strongmade 2" lift kit, brackets on bottom, will work with Fox Shocks. $50
Pictures of bumper, wheels and tires, detailed pictures of lift and install on my garage thread, link on my profile page.
View attachment 124930 View attachment 124931 View attachment 124932
Cool thanks.If you’re not getting anyone else’s I’ll sell just the fronts.
Do all 4 corners!Cool thanks.
I wonder is I just do fronts do I need to do backs?
Cool thanks.
I've got a full set of deluxe shocks for a 1000-5 if anyone is interested.Do need to know before I leave Tuesday morning though.
There you go, your covered! 3 Sets of fronts available!Cool thanks.
