21 Talon dying on take off
Jacob715
Jacob715
12
19
MO
Hello there. We have a 21 talon that feels like you are "dumping the clutch" when you go to take off in high gear. Tried new clutches, still no change on feel. Feels like the converter is maybe locked on take off. No codes are popping up, relearn clutch procedure has been tried a few times. Checked wiring, a little stumped at this point.
When you go to take off, unit revs a few hundred rpms before engagement, its harsh enough hit that if you don't throttle more, it will stall out and die
Red500
Red500
5,447
59,209
Greeneville, Tn.
Well there's some idiot on here that is advancing the theory that it might just be playing dead, but I wouldn't believe anything he says. I don't have a clue but I'll say hang around long enough and someone will have your answer.
Welcome to the club from East Tennessee.
PaulF
PaulF
1,462
4,810
Have you tried a clutch re-learn?
Have you installed an aftermarket tune or messed with the DCT tuning? If so, go back to stock and see if that makes any difference.
Jacob715
Jacob715
12
19
MO
We did at one point try an ecu from another talon, no changes though
PaulF
PaulF
1,462
4,810
No codes or lights on of any kind?
PaulF
PaulF
1,462
4,810
Clutches are heavily dependent on oil pressure. What is the oil pressure?...
1658350860362
Jacob715
Jacob715
12
19
MO
can't remember off top of my head, but was within spec on oil. Old clutches were slipping, no sliggage with new.
Jacob715
Jacob715
12
19
MO
tried clutch relearn today again, it didn't seem to want to complete relearn, had errors pop up on trip back, now need to get back to a code reader
PaulF
PaulF
1,462
4,810
And the original clutches did the same thing or they only slipped?
Did you replace all the seals, o-rings and seal rings on the clutch shafts and clutch housings?
Did you verify the clutch clearance?
