P1000 Bed will not dump
108,108
Not sure how I posted this comment lol but I found the center latch under the rear seats where they join to the inside of each. It isn't releasing but will with minimal downward pressure applied to a seat. Solution?
Sounds like you need to adjust the center latch. Did u do any mods to quiet the bed rattles? That can hinder that latch releasing properly at times
JenElio
JenElio
65,831
614,003
Loxahatchee, florida
Thank you, I lowered these wedges but it didn't do anything. Found that by applying minimal pressure to the center of the bed where the seats adjoin it will release the center latch. Now to the next solution.
Did you notice if there are 2 little rubber caps on the ends of the latch where it needs to be pressed down? If these are missing, it could be enough to cause the issue.
Also, once you lift the bed, the latches are adjustable some I believe.
William
William
1,442
2,887
Flowood MS
A guy at my deer camp had this problem, and so did i… On both of ours, it was the clip for the nets wedging on the rear door… the one attached to the cage.
A
arl242
14
23
Tipton, MO
I didn't see any rubber caps.
