cheep fixes for ratting doors and bed
W
wvrider
14
Does anybody doors and bed rattles except mine? If so here is a low cost fix. For the bed look were it latches and then cut a piece of fuel line 5/16 or so and put it around the latch strike and then zip tie it together then put a little grease on it. and for the doors just wrap the strike plate with black tape and grease it too yea this will wear out but what a difference it makes I hate rattles. You can adjust the door stops but that did not help mine.
SkyPup
151
14
White lithium spray grease works great!
Lynn
Lynn
263
134
Yakima,WA
Just screw the rubber bumper on the door from in or out to adjust, that's what there for. Also the bed latch is adjustable. just loosen the bolts and move the latch closer or farther away.
64,595
Keep in mind the door is a dual lock latch. So make sure it is closed all the way and in the second catch point. If not it will give you lots of rattle.
L
longbeards
79
23
THANKS<<<I HATE THE RATTLE I AM GETTING IN THE BED!! I WILL TRY THAT TODAY!! ON the doors check to see that the bolt holding the lock is not coming losse,,it has on both of my doors! Saw you are from WV,,I am from Hardy County! longbeards
