[parsehtml]<h2>Compare Your Pioneer 500</h2>
<table class="specs" summary="engine">
<thead>
<tr>
<th width="128"></th>
<th width="329" scope="col"><div align="center">Pioneer 500</div></th>
<th width="317" scope="col"><div align="center">Pioneer 700</div></th>
<th width="314" scope="col"><div align="center">Pioneer 700-4</div></th>
<th width="8" scope="col"></th>
</tr>
</thead>
<tbody>
<tr>
<th scope="row">Images</th>
<td><div align="center"><span class="model sxs700m2e sxs"><img src="http://powersports.honda.com/Assets/Models/2015_Pioneer500_145x90_Red_trans.png" alt="2014 Pioneer 700" /></span></div></td>
<td><div align="center"><span class="model sxs700m4e sxs"><img src="http://powersports.honda.com/Assets/Models/2014_Pioneer700_145x90_Olive_trans.png" alt="2014 Pioneer 700-4" /></span></div></td>
<td><div align="center"><span class="model blank "><img src="http://powersports.honda.com/Assets/Models/2014_Pioneer7004_145x90_Red_trans.png" alt="No Model" /></span></div></td>
<td></td>
</tr>
<tr>
<th scope="row">Specs.</th>
<ul class="miniSpecs">
<li>475cc liquid cooled single cylinder four-stroke</li>
<li>Red, Olive, Yellow and Honda Phantom Camo™</li>
</ul>
</div></td>
<li>675cc liquid-cooled OHV single-cylinder four-stroke</li>
<li>Honda Automatic Transmission</li>
</ul>
</div></td>
<li>2-3-4 Seating Configuration</li>
</ul>
</div></td>
<td></td>
</tr>
<tr>
<th scope="row">Pricing</th>
<td><div align="center">Starting at <span class="price">$8,499</span></div></td>
<td><div align="center">Starting at <span class="price">$9,999</span></div></td>
<td><div align="center">Starting at <span class="price">$11,699</span></div></td>
<td></td>
</tr>
</tbody>
</table>
<p> </p>
<p> </p>
<h3>Engine</h3>
<thead>
<tr>
<th></th>
<th scope="col">Pioneer 500</th>
<th scope="col">Pioneer 700</th>
<th scope="col">Pioneer 700-4</th>
<th scope="col"></th>
</tr>
</thead>
<tbody>
<tr>
<th scope="row">Engine Type</th>
<td>475cc liquid cooled single cylinder four-stroke</td>
<td>675cc liquid-cooled OHV single-cylinder four-stroke</td>
<td></td>
</tr>
<tr>
<th scope="row">Bore And Stroke</th>
<td>92.0mm x 71.5mm</td>
<td>102.0mm x 82.6mm</td>
<td></td>
</tr>
<tr>
<th scope="row">Compression Ratio</th>
<td>9.5:1</td>
<td>9.2:1</td>
<td>9.2:1</td>
<td></td>
</tr>
<tr>
<th scope="row">Induction</th>
<td>Electronic fuel injection (PGM-FI), 36mm throttle body</td>
<td>Fuel Injection (PGM-FI), 40mm throttle body</td>
<td></td>
</tr>
<tr>
<th scope="row">Ignition</th>
<td>Full-transistorized type with electronic advance</td>
<td>Full-transistorized with electronic advance</td>
<td></td>
</tr>
</tbody>
</table>
<h3>Drive Train</h3>
<table class="specs" summary="drive train">
<thead>
<tr>
<th width="327" scope="col">Pioneer 500</th>
<th width="317" scope="col">Pioneer 700</th>
<th width="317" scope="col">Pioneer 700-4</th>
<th width="7" scope="col"></th>
</tr>
</thead>
<tbody>
<tr>
<th scope="row">Clutch</th>
<td>Automatic</td>
<td>Automatic</td>
<td>Automatic</td>
<td></td>
</tr>
<tr>
<th scope="row">Transmission</th>
<td>Electric-shift five-speed with reverse (First gear is L = LOW)</td>
<td>Automotive-style with hydraulic torque converter, three forward gears and Reverse. Three drive modes include 2WD, 4WD and 4WD with differential lock</td>
<td></td>
</tr>
<tr>
<th scope="row">Driveline</th>
<td>Direct front and rear driveshafts</td>
<td></td>
</tr>
</tbody>
</table>
<h3>Chassis / Suspension / Brakes</h3>
<table class="specs" summary="chassis / suspension / brakes">
<thead>
<tr>
<th width="129"></th>
<th width="330" scope="col">Pioneer 500</th>
<th width="321" scope="col">Pioneer 700</th>
<th width="308" scope="col">Pioneer 700-4</th>
</tr>
</thead>
<tbody>
<tr>
<th scope="row">Front Suspension</th>
<td>Independent double-wishbone; 5.9 inches travel</td>
<td>Independent double-wishbone; 7.9 inches travel</td>
<td></td>
</tr>
<tr>
<th scope="row">Rear Suspension</th>
<td>Independent double-wishbone with preload adjustablility; 5.9 inches travel</td>
<td>Independent double-wishbone; 9.1 inches travel</td>
<td></td>
</tr>
<tr>
<th scope="row">Front Brake</th>
<td>Dual hydraulic 190mm discs</td>
<td>200mm hydraulic disc</td>
<td></td>
</tr>
<tr>
<th scope="row">Rear Brake</th>
<td>170mm hydraulic disc</td>
<td></td>
</tr>
<tr>
<th scope="row">Front Tires</th>
<td>24 x 8-12</td>
<td>25 x 8-12
</td>
<td>25 x 8-12
</td>
<td></td>
</tr>
<tr>
<th scope="row">Rear Tires</th>
<td>24 x 10-12</td>
<td>25 x 10-12</td>
<td>25 x 10-12</td>
<td></td>
</tr>
</tbody>
</table>
<h3>Dimensions</h3>
<table class="specs" summary="dimensions">
<thead>
<tr>
<th width="132"></th>
<th width="329" scope="col">Pioneer 500</th>
<th width="323" scope="col">Pioneer 700</th>
<th width="305" scope="col">Pioneer 700-4</th>
</tr>
</thead>
<tbody>
<tr>
<th scope="row">Length</th>
<td>102.5 inches</td>
<td>114.8 inches</td>
<td></td>
</tr>
<tr>
<th scope="row">Width</th>
<td>50.0 inches</td>
<td>60.0 inches</td>
<td></td>
</tr>
<tr>
<th scope="row">Height</th>
<td>72.4 inches</td>
<td>77.6 inches</td>
<td>78.3 inches</td>
<td></td>
</tr>
<tr>
<th scope="row">Wheelbase</th>
<td>73.1 inches</td>
<td>76.8 inches</td>
<td></td>
</tr>
<tr>
<th scope="row">Towing Capacity</th>
<td>1000 pounds</td>
<td>1500 pounds</td>
<td></td>
</tr>
<tr>
<th scope="row">Ground Clearance</th>
<td>9.6 inches</td>
<td>10.5 inches</td>
<td></td>
</tr>
<tr>
<th scope="row">Turning Radius</th>
<td>12.8 feet</td>
<td>14.8 feet</td>
<td>14.8 feet</td>
<td></td>
</tr>
<tr>
<th scope="row">Curb Weight</th>
<td>1010 pounds - Includes all standard equipment, required fluids and full
tank of fuel.</td>
<td>1261 pounds - Includes all standard equipment, required fluids and full
tank of fuel.</td>
<td>1396 pounds</td>
<td></td>
</tr>
<tr>
<th scope="row">Fuel Capacity</th>
<td>4.1 gallons, including 1.1-gallon reserve</td>
<td>8.2 gallons, including 1.2-gallon reserve</td>
<td></td>
</tr>
</tbody>
</table>
<h3>Other</h3>
<table class="specs" summary="other">
<thead>
<tr>
<th width="133"></th>
<th width="323" scope="col">Pioneer 500</th>
<th width="314" scope="col">Pioneer 700</th>
<th width="318" scope="col">Pioneer 700-4</th>
</tr>
</thead>
<tbody>
<tr>
<th scope="row">Note</th>
<td></td>
</tr>
<tr>
<th scope="row">Available Colors</th>
<td>Red, Olive, Yellow, Honda Phantom Camo™</td>
<td>Red, Olive, Honda Phantom Camo™</td>
<td></td>
</tr>
<tr>
<th scope="row">Model Id</th>
<td>SXS500M2F</td>
<td>SXS700M2</td>
<td>SXS700M4</td>
<td></td>
</tr>
</tbody>
</table>
</div>[/parsehtml]
<thead>
<tr>
</tr>
</thead>
<tbody>
<tr>
<td></td>
</tr>
<tr>
</ul>
</div></td>
</ul>
</div></td>
</ul>
</div></td>
<td></td>
</tr>
<tr>
<td></td>
</tr>
</tbody>
</table>
<p> </p>
<p> </p>
<h3>Engine</h3>
<thead>
<tr>
<th></th>
</tr>
</thead>
<tbody>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td>9.5:1</td>
<td>9.2:1</td>
<td>9.2:1</td>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
</tbody>
</table>
<thead>
<tr>
</tr>
</thead>
<tbody>
<tr>
<td>Automatic</td>
<td>Automatic</td>
<td>Automatic</td>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
</tbody>
</table>
<thead>
<tr>
</tr>
</thead>
<tbody>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td>24 x 8-12</td>
<td>25 x 8-12
</td>
<td>25 x 8-12
</td>
<td></td>
</tr>
<tr>
<td>24 x 10-12</td>
<td>25 x 10-12</td>
<td>25 x 10-12</td>
<td></td>
</tr>
</tbody>
</table>
<h3>Dimensions</h3>
<thead>
<tr>
</tr>
</thead>
<tbody>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td>9.6 inches</td>
<td></td>
</tr>
<tr>
<td>12.8 feet</td>
<td>14.8 feet</td>
<td>14.8 feet</td>
<td></td>
</tr>
<tr>
tank of fuel.</td>
tank of fuel.</td>
<td></td>
</tr>
<tr>
<td></td>
</tr>
</tbody>
</table>
<h3>Other</h3>
<thead>
<tr>
</tr>
</thead>
<tbody>
<tr>
<td></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td>SXS500M2F</td>
<td>SXS700M2</td>
<td>SXS700M4</td>
<td></td>
</tr>
</tbody>
</table>
</div>[/parsehtml]
