DCT engagement rpm
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I’m looking for a way to raise the engagement RPM.
Anyone know of a way?
SLOWPOKE693
SLOWPOKE693
1,632
6,208
Somewhere in Texas
Very intrested in this for my racecar. I have no use for launch control, but raising the DTC engagement RPM would be pretty slick.
Reactions: Sheetmetalfab
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
I do not remember seeing a specific option in the PV3 to raise the take off RPM (Flash) but I'm pretty sure you can raise the idle rpm and achieve some. It engages the clutch at xxx number of rpm over where it is idling. There are a few adjustments in the line pressure settings that may be able to trick the system.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I’ll try with my pv3 when I get a chance.
Currently running dynojet tune with raised rev limiter and happy vs stock.
Reactions: CID
PaulF
PaulF
1,462
4,810
DynoJet added a BUNCH of DCT stuff to the PV3. Update your software and start from a stock tune (you cannot modify a DJ tune)...
1622756668457
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
So I modified a stock tune and raised idle rpm 500 in every category respectively.
The engagement did not increase along with it.
Back to the DJT tune for now and will dig into the stock tune settings again maybe for something related.
Reactions: CID
PaulF
PaulF
1,462
4,810
I believe the engagement is not RPM based but rather TPS based. From what I can tell in C3 programming software, Clutch Line Pressure is 43.41 in-hg (~21 psi) at "Idle" (Mode 10) and then increases during "Take-Off" (Mode 15) based on TPS and is then controlled from there in "Transient" (Mode 25) based on TPS, RPM and Slip until it reaches "Steady State" (Mode 30) where it locks up the clutch with up to 200+ in-hg (100+ psi). On the way back to a stop, there are "Deceleration" pressures and "disengagement" points factored in.
To raise the engagement RPM (give the clutch a little more "controlled" slip) I think we should try lowering the pressures in this table in a progressive manner. 14% on the first line then 12, 10, 8, 6, 4, 2% and leave the last line as is and see what that does. It is pretty drastic but will for sure tell us if we are on the right track. Get some base logs for reference and adjusted logs and compare. Then tweak it from there if it actually works...
1625772083632
From this...
1625772232354
To this...
1625771174357
