P1000 Fox shocks worth it?
Lady01
Lady01
192
488
Midland Michigan
Lady01: The world's choking on sycophants. I appreciate the lone wolf opinion expressed heads up.
I'mma big fan of good enough. From advice given to me: Better is the mortal enemy of good enough.
I really enjoy the this forum even those that disagree with me. So, let me state that I do have Fox QS3 installed. I had the 3" bracket lift and removed them for the FOx Shocks install. At $1500 or so, again they are a nice ride but there are a lot of other things I would have used the money for than simply a better ride... nice, yes, worth the cost? Not for me!
Vikes79
Vikes79
SKOL!
11,092
107,678
South Dakota
  2. Talon X4 LV
I would argue that most everyone that is upgrading their shocks, are starting with the base model shocks like myself and not a model that already has the Fox shocks…
The difference between the base shocks and the foxs are night and day. My family was so much happier afterwards on the trails.
I agree that going from the Qs3 to another is quite a small step for a lot of coin.
Scoop
Scoop
4,278
16,031
  3. Talon R LV
Low profile on 12" rim works best for deep mud.
Yep! Mah new set:
1687437200962
Robobrainiac
Robobrainiac
2,475
8,662
Just in case you might consider a different brand. Here is a recent rough country post.
Reactions: ChadD
Bombardier Convert
Bombardier Convert
324
1,110
Minnesota USA
Would Fox shocks give me a little more weight carrying capacity? Not sure how much that load weighs but the rear end really squats down with it.
Media 1687606557903 Jun 23 2023 3 52 PM
Scoop
Scoop
4,278
16,031
  3. Talon R LV
If you regularly carry more than your springs are rated for, they're gonna be compressed with little/no room to travel under that load.
You can add preload with the Fox's and similar coilovers, but that will only raise the machine and reduce the shock travel. So the "help" is marginal, but at a cost when unloaded.
I'm no suspension expert like @Smitty335, but I'd put stiffer springs rated for more weight if you go with Fox's and dump the progressive rate springs they come with. You'll also get the added benefit of being able to adjust preload to raise it up some.
I swapped out the springs on my Fox's before I installed them. Used a 250# linear rate spring on the front and 300# on the rear. Depending upon how much weight you will regularly carry, that may require different spring rates. Just keep in mind the stiffer you go, the stiffer the ride will be when empty.
As a comparable, one of the few differences between an F250 (3/4 ton) and an F350 (1 ton) pickup is an added leaf in the rear. This allows it to carry more weight (before sagging) but the unloaded ride is more harsh.
Again, I'm no expert, so let some others chime in here.
Bombardier Convert
Bombardier Convert
324
1,110
Minnesota USA
That's a good answer! There is always a tradeoff on making changes and making a change to be able to carry more load weight will make a much harsher ride when unloaded. We use this machine for multipurpose activities so hate to wreck it for half of the times we use it just to trail ride.. maybe I need to just get a separate wood hauler? Lol!
208,029
Trailer?
Scoop
Scoop
4,278
16,031
  3. Talon R LV
How much weight are you putting back there? My 2021 P1K5 Dee-lux is rated for 1,000# cargo capacity (stock suspension). I've hauled a lot of wood in my time (nohomo), and that doesn't look like anywhere near half a ton.
If you do a trailer, your towing capacity is 2,000#.
Bombardier Convert
Bombardier Convert
324
1,110
Minnesota USA
This load is probably a little closer to 1000 lbs.. green fresh cut maple.. I have used a trailer at times but it makes it a little more difficult to get it out of the woods where I go.
Screenshot 2023 06 25 085948
