P500 Help
herd90
17
37
So, torq locker installed, ps, front brakes, winch, @trigger heat shield has arrived. New skid plates and getting 8 ply radials 26-9/12 on all 4 today. I'm a true amateur mechanic and unsure where to permanently mount all this and roll. 2nd battery? F1b27e0db76f20266d2ebe3d702f21498bb4d787a439a863ac4998048f7ed7204409f956fdb1b45f7baddf1dd7595c2eCf186ce83ab8bc54a4c6b8b4d4ace6a4F339dbf86903daed8af3b8202c223c09
Sent from my SM-G975U using Tapatalk
Reactions: trigger
herd90
17
37
Location?Cc26abd23b3965e84d820506cadf8862
The Green Goat
The Green Goat
1,812
12,956
Ohio
I'll take a pic of my setup when I get home tonight. It's not installed, yet, but it'll give you idea of what I am planning on doing.
Reactions: herd90
herd90
17
37
Really like to see a picture of the set up. I haven't zip tied or screwed anything down yet.
The Green Goat
The Green Goat
1,812
12,956
Ohio
Doh! sorry. forgot about this. Setting myself a reminder to take a picture tonight when I get home.
Reactions: futzin and herd90
The Green Goat
The Green Goat
1,812
12,956
Ohio
Crappy pics, but Hopefully you get the idea of what I'm doing.
Pathway will be:
Main battery > Blue Sea Mini add-a-battery > Aux battery pos > 500a Stinger relay (on via ignition or switch; haven't decided) > 200a Blue Sea breaker > red BUS bar > relay boxes (2 on aluminum plate for random things, 1 on shock brace for Auxbeam switches) > various accessories > black BUS bar > Aux battery neg.
35ah Mighty Max battery will be mounted inside the battery box which will be mounted in the aluminum tray I had made, and this will be mounted under the driver seat on the frame.
BS-MAAB and its Automatic Control Relay will be mounted on the vertical plastic panel between the driver and passenger side by you legs.
Everything except Auxbeam relay box will be mounted to the 1/4" x 8.5" x 10" aluminum plate I had cut. This will be mounted to the shock brace. Stinger and breaker will be mounted to the bottom of the plate.
20210412 195043
20210412 195029
20210412 195110
20210412 195514
20210412 195607
herd90
17
37
Yeah that's awesome @The Green Goat. I'd like to work with what I have on hand. Thank you for taking those pictures!
Reactions: Mudder and trigger
rustyneversleeps
rustyneversleeps
381
1,833
Montana
Torq locker, ps, front brakes, winch, @trigger heat shield, 26" tires. Bought several tools I'd have never owned. Thanks to this forum for sharing your thoughts. View attachment 267154
Looks good man - what tools did you end up buying?
herd90
17
37
7/32" pin punch, crimping tool, pry bar, 3/8" long handle ratchet and 20ft of 6 ga copper wire with a wire cutter.
